swoosh's build thread....the HIGH PROTEIN DIET !!! (Updated Pics-Page 74-7/12/15)
Old 07-24-2015, 04:48 PM
  #3001
Jeff
Oh Sickest TL's Avatar
Originally Posted by N1h1l1ty
or do it yourself -
Old 07-24-2015, 04:52 PM
  #3002
Confusing Name Guy
N1h1l1ty's Avatar
Originally Posted by Oh Sickest TL
You need a dremel, a dremel flex shaft, some basic dremel bits, youtube and patience. It really isn't that hard. Its kind of the same with head polishing - oftentimes the charge for the work is high not because of the technical proficiency required but because of the sheer amount of time it takes to fully PnP a head.
Compared to, gasket matching some runners is nothing lol
Oh Sickest TL (07-24-2015)
Old 07-24-2015, 04:53 PM
  #3003
Jeff
Im a chemical technologist not a machinist dawg lol
Old 07-24-2015, 04:55 PM
  #3004
Confusing Name Guy
N1h1l1ty's Avatar
Old 07-24-2015, 06:09 PM
  #3005
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
Yeah, because you've done it before.
No...you've just read it's really easy. You try first!
Old 07-24-2015, 06:24 PM
  #3006
Jeff
not something I would even think to attempt myself
Old 07-24-2015, 06:35 PM
  #3007
Confusing Name Guy
N1h1l1ty's Avatar
I've worked with rotary tools enough outside of automotive stuff to have a good idea (in my opinion of course). I don't think its "easy" per se and does require some precision, but I don't think its extremely difficult, and the runners are magnesium so there's no extra material concerns like there are with the 3.7 IM. I just think if you're relatively experienced with a rotary tool and have some patience you could probably get it done with good results. Just my
Also keep in mind with the runners you only need to gasket match the intake manifold side. I believe porting the head side is not recommended because of turbulence concerns.
Old 07-24-2015, 06:53 PM
  #3008
Turbulence? Like a plane!
Old 07-25-2015, 08:29 AM
  #3009
Confusing Name Guy
N1h1l1ty's Avatar
I can't remember the term that was used now
Issues with ported runners but un-ported heads
Old 07-25-2015, 10:04 AM
  #3010
That was the term!
Old 07-25-2015, 10:12 AM
  #3011
Jeff
word tho
Old 07-25-2015, 11:13 AM
  #3012
Confusing Name Guy
N1h1l1ty's Avatar
On another note, I have a question for you Anil: Where did you place your AFR bung on the exhaust? At the jpipe or past it? And you needed PCDs for that reason if I remember correctly, right? I think it was covered somewhere in the MS3 thread but I slogged through that nightmare once and I'm not sure I'll be able to find it again. I'm going with PCDs regardless, but I plan to either weld or make a bracket for a race cat onto my catback and wanted an idea of where to place it
EDIT: If I recall correctly, it was a matter of a cat skewing the AFR reading / exhaust gases after cat potentially burning out the sensor? One of the two (or both?)
Old 07-25-2015, 02:58 PM
  #3013
3.5 psi
gnuts's Avatar
If you have pcd then put it on the jpipe after the merge.
Old 07-25-2015, 07:22 PM
  #3014
Confusing Name Guy
N1h1l1ty's Avatar
Makes sense lol
Old 07-25-2015, 11:31 PM
  #3015
you sure are building quite the theoretical racekor, N1.
Acura TL Builder (04-11-2021)
Old 11-24-2015, 07:19 PM
  #3016
Jeff
swoosh man where ya at brother.
Old 12-01-2015, 12:47 PM
  #3017
Slot Machine Lubricator
1black_seven's Avatar
^Somewhere in Overland Park
Old 12-02-2015, 06:00 PM
  #3018
nismotypeS's Avatar
What brand is your carbon fiber hood? btw your car looks amazing!
Old 12-02-2015, 10:20 PM
  #3019
Life Connoisseur
MonkeyTrucker's Avatar
Originally Posted by swoosh
I see the bar on proper waxing has been set, amazing. Great pics!
Old 12-03-2015, 07:33 AM
  #3020
screaminz28's Avatar
That mirror finish is from proper paint correction and polishing. Wax is nothing more than a final protectant - it will look like that without ANY wax.
Old 12-03-2015, 07:51 AM
  #3021
well, and plus the sun isn't shining on it
agupta3224
05-23-2017 08:30 AM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
rockyboy
09-29-2015 12:05 AM
navtool.com
09-25-2015 05:15 PM
Quick Reply: swoosh's build thread....the HIGH PROTEIN DIET !!! (Updated Pics-Page 74-7/12/15)
