Just did my isimple installation (pics)
i had about half an hour to spare and decided to start my installation. It was very easy and only had to remove a few trims (not the entire dash).
I would like to specified some of the concern i had before the installation. The harness you need is the one closest to the driver side. (is at the left side of the radio which makes it easier)
you have enough room to be able to touch the hardness with your fingers and even remove it without the needs of tool (tools makes it easier, without tools is hard but possible). I used a hanger to remove the harness when it was amost out i used my fingers. Used a flat head screw drivers to place it back in.
THIS IS NOT A DIY. JUST TO GIVE YOU AN IDEA WHERE THE HARNESS IS LOCATED.
This is the version i installed, (04-08) ISHD571
XM still works, Steering wheel controls works. i read somewhere that to switch tracks from the steering wheel you have to do a long press, Not with this version of isimple, it just a simple touch.
![](http://i177.photobucket.com/albums/w207/eduardmc/IMAG0228.jpg)
![](http://i177.photobucket.com/albums/w207/eduardmc/IMAG0231.jpg)
![](http://i177.photobucket.com/albums/w207/eduardmc/IMAG0232.jpg)
![](http://i177.photobucket.com/albums/w207/eduardmc/IMAG0234.jpg)
![](http://i177.photobucket.com/albums/w207/eduardmc/IMAG0235.jpg)
![](http://i177.photobucket.com/albums/w207/eduardmc/IMAG0236.jpg)
![](http://i177.photobucket.com/albums/w207/eduardmc/IMAG0237.jpg)
under renovations....
I got the same unit and I have problems with it. At first when I plugged it in I got nothing as in no screen or anything. Then I kinda forced the plugs a bit more and got my radio back on but still no screen then I did it again and got mine screen back on and the radio back on but it didn't show the ipod or anything like that. I tried this damn thing like 10x and still nothing. I'm about to send mine back for a refund. I ordered it off of amazon with a top seller too. They told me I can either get a refund or exchange it. Which plug harness did you get the PGHHD1? I read here that people had issues with it and that another one was replaced for it PGHHD2. I got the PGHHD1 harness but I don't know if it's right cause I have xm on but I'm not using navtraffic. I'm at a loss with this. Oh the unit was charging my ipod btw but for some reason it just didn't recognize it. My ipod and Iphone are both updated as well.
do you have the traffic device in your system but not enable with xm?
To be able to have traffic you need an adapter, i believe is in the trunk. even if you are using traffic or does not have it enable you have to install isimple after the device. So in your case if you have the device, your isimple installation should be in the trunk area. For non traffic device you connect it to the back of the radio.
When I first hooked it up I got nothing no screen no sound like it was off. I fiddled with the harness some then I got sound back but still no screen then I did it again and got the screen back but couldn't change any stations or anything. When I got it all back it didn't even show the ipod it was charging it but not showing it at all. There's got to be a problem within the connections to the unit or just the plugs are crappy I dunno. I gave up at like 10 tries and pulled it out and put everything back to normal. I did exactly how it said to install it and go thru the proper motions to get it to work but nothing.
Why me??
was the unit updated with the latest firmware version? you didnt touch the dip switches by accident did you? if not, did you remove the sticker covering them to make sure they were all in the off
position? ive seen them be in different positions even with the sticker covering them.
6SPEED FEVER
I believe it was updated with the latest firmware because my iPod is update and so is my iPhone. I didn't touch any of the dip switches and they were all off. I even made sure by pushing them towards the off position just in case any were stuck in the middle but they were good. I wound up sending the unit back today so they can send me another one to try and if this one doesn't work then I'll scratch the whole isimple idea for the time being. When I get the new one in Ill post up my results.
I heard somewhere that once in awhile you would need to upgrade the firmware.
How much of a trouble for you guys to take it back out every time for upgrade?
I guess you can't really put it anywhere else that's easy to access, since the cables are pretty short? I don't have one, just assuming from the picture. Planning on getting one very soon, can't drive anywhere without my ipod...
I installed mine today. It works but with a bit of a delay, like its slow to respond. Also, can't get the steering wheel controls to work. thats probably one of the biggest things I wanted it to do. I removed and reinstaleld. Not sure what it isn't doign it. I'll have to troubleshoot some more. Sucks.
I installed mine last week. My issue was it was supposed to go in the trunk to the xm unit (nav traffic equipped). But I can get the steering wheel to work either right now the only thing it'll do is put repeat on IIRC. I finally got the hang of switching over from SAT to IPOD and using the tuner knob to cycle through the tracks but that too can be a PITA. I can do it faster on the ipod itself. I guess I have to toy around with it.
Vejey Gandier
09-12-2015 08:59 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
