3.7 L throttle body ?
Old 10-18-2016, 10:26 PM
D-Ramey's Avatar
Ive been very curious if its worth the swap with just the throttle body or throttle body and intake manifold ? i have access at work to possible get both for cheap i havent found much online can anyone give me a testimony on just the thottle body and maybe a spacer and or throttle body an mani ?
looking for alittle more throttle response for sure ! thanks
Old 10-19-2016, 07:39 AM
TheTLProject's Avatar
I have both on my 06 Base Auto and didn't really feel a difference at all. Only gained 3hp on peak power. Way over priced for the gains you get. Just pick yourself up the 3.5 IM/TB and save some money.
Old 10-19-2016, 07:42 AM
D-Ramey's Avatar
i have a auto tl-s so i already have the 3.5 and i can get a throttle body for 35-50$ at work so not to bad in price the manifold i found for 90$ i just wanted to know if i have to have the car tuned and is everything bolt up? and what id need to complete the full swap and is it really worth it ive heard guys having bucking issues an drivability i dont wanna run into all of that
Old 10-19-2016, 07:48 AM
Received 16,260 Likes on 11,971 Posts
sounds like you answered your own question.
the previous poster above you pointed out that there was only a 3whp gain, that would be even LESS gains for your 3.5L engine....
then, you ask..."would I need to get it tuned to get full potential?"
a big fat
if previous poster only gained 3whp on his 3.2 without being tuned.....
Old 10-19-2016, 09:11 AM
mrkingstonvi's Avatar
Ive been very curious if its worth the swap with just the throttle body or throttle body and intake manifold ? i have access at work to possible get both for cheap i havent found much online can anyone give me a testimony on just the throttle body and maybe a spacer and or throttle body an mani ?
Your best bet to get best gains without a tune is to get the 3.7 Manifold, 3.7 Throttle body, 3.5" - 4" Intake, and Port & Polish runners all together. To get maximum gains with these mods you will need a tune to squeeze the remaining power. Since you are getting the Manifold & Throttle body cheap from your job, I would suggest you pick them up as others have paid $450+ on this setup. I spent $754.18 shipped (I was living in the islands at the time) on this setup which included the 3.7 manifold cover and some nuts and bolts.
Prices look like this brand new from dealer without the manifold cover as you can reuse your 3.5 cover. (3.2 users have to get either the 3.5 / 3.7 manifold cover):
17160-RK2-A00 INTAKE MANIFOLD $243.02
16400-RYE-A11 THROTTLE BODY $208.18 (This is the ZDX Throttle body btw)
16176-RYE-A10 GASKET $0.52
17140-RK1-A01 COVER, IN. MANIFOLD (UPPER) $189.63
17105-RCJ-A01 MANIFOLD GASKET $25.48
kevski3oh5 (10-19-2016)
Old 10-19-2016, 10:11 AM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
But you are still running that aem intake right?
OP did you search and read I love car's thread?
Old 10-19-2016, 11:48 AM
This is the thread that EvilVirus is referring to D-Ramey ----> https://acurazine.com/forums/3g-tl-p...thread-870327/
Short summary:
Originally Posted by i_love_cars
This mod is recommended for people who are already bolted on with exhaust mods and want to take their car further, potentially with the tuning given in the new Flashpro solution for 07-08 TL's.
Performance Gains
Weight reduced by a few pounds (3.7 manifold is magnesium and the 04-08 IM is aluminum)
Air/Fuel ratios evened out quite well with this mod - I had been previously running very rich with all my exhaust mods, around 11.4. Once the 3.7 was on and air flow was increased, it leaned out to more expected levels of 12.3 or so. Pretty good for stock ECU.
Without a port and polish, just the 3.7 IM/TB, I saw about 7 whp / 5 wtq gain, and I was already fully bolted on with exhaust, HFPC's, jpipe, and aem v2 intake. This is also without a tune. Here is my dyno chart of before/after:
It is assumed that a 3.2 TL would gain more from this mod as the 3.5 Type-S intake manifold flows more already, so the jump to the 3.7 isn't as big as it would be from the 3.2 platform.
With port and polish expect minimal gains over what I got - the 3.7 flows very well already. There are gains to be had with ported runners, though. to the tune of 5-10 whp. Also if you already have a PnP'ed intake manifold on your current 3.2 or 3.5 manifold, this swap to the 3.7 won't gain you much if anything.
Conclusion
Will benefit from a tune greatly but still offers good mid-range and top-end gains.
The following 2 users liked this post by mrkingstonvi:
EvilVirus (10-19-2016), kevski3oh5 (10-19-2016)
Old 10-19-2016, 10:42 PM
kevski3oh5's Avatar
My question is tho, why do alot of people use the 3.7 ZDX throttle body instead of the 3.7 TL throttle body? Is it because you can bore out the outlet of the ZDX more than the 3.7 TL throttle body?. I've dug through and came across on a thread saying because of that reason... Also because Mr. heeltoeauto.com has the 3.7 TL throttle body for $175 and the 3.7 ZDX for $239 that's a $64 difference & another thing the 3.7 TL has an Inlet of 80mm and the ZDX has a 78mm but both have the same 70mm outlet.... Can somebody explain this to me this is the part I'm a little confused on ????
EvilVirus (10-20-2016)
Old 10-20-2016, 12:50 PM
_Camus_'s Avatar
I would like to know the answers as well, I was baffled the last week because I bought the TB from an Odyssey, hoping to have a bigger TB than my current J32 TB, turns out it's the same size, also the TB from the Type S is the same size. Where we can find the exact sizes of each engine? I'm really interested in knowing what it's going on with this as well.
Old 10-20-2016, 11:28 PM
DomGSR-T's Avatar
At the time, the ZDX TB was a lot cheaper than the 3.7TL
Here's the same day dyno tests I made with my TL-S with different TB and other cool things... this will answer most of your questions
https://acurazine.com/forums/3g-tl-p...no-day-920438/
The following 2 users liked this post by DomGSR-T:
EvilVirus (10-21-2016), kevski3oh5 (10-21-2016)
Old 10-21-2016, 04:17 PM
kevski3oh5's Avatar
Dom you said on your post that you liked the power gains you got from your stock throttle body combined with your 4" intake you think it will be worth putting a 3.5" intake on my stock base 3.2 ? I've been itching to do a intake mod but don't know either to wait to get j-pipe/exhaust & the 3.7 mani/3.7tb
Old 10-22-2016, 10:59 AM
kevski3oh5's Avatar
to OP to answer your question here's a good link to answer your question as well
http://www.vX6Xperformance.net/forums/7g-honda-accord-performance-discussion/243257-big-bore-throttle-body-truth.html#/topics/243257?_k=lvmoal
Take off the X when you search it...
The topic in that thread is pretty logical if you're gonna go with just the throttle body is better to to both 3.7 manifold/3.7 throttle body.. If you just put the throttle body you would cause "turbulence" it would be best to match bore the outlet (the back) of the throttle body and the opening of the manifold to get it's full effect
EvilVirus (10-24-2016)
00TL-P3.2
02-11-2019 11:23 AM
Faisel
08-28-2016 10:06 AM
hues10
1G RDX (2007-2012)
06-18-2016 08:40 AM
velvethammer
06-01-2016 06:57 AM
Quick Reply: 3.7 L throttle body ?
