Remote Start
Old 03-19-2014, 09:47 AM
Grandpa
George Knighton's Avatar
Received 2,609 Likes on 1,475 Posts
Remote Start
Anybody have the Acura dealer installed remote start on an RLX?
If you do, does the remote start shut off when you open the door, or have they changed that in this generation?
Old 03-19-2014, 11:13 AM
9th Gear
Pecker's Avatar
The engine will shut off, just like all of the other Acuras, except for the '14 MDX. The '14 MDX remote engine start fob replaces the OE smart fob and allows entry into the vehicle with out engine shut off. I wish the RLX was designed to do the same.
Old 03-19-2014, 11:31 AM
neuronbob's Avatar
Received 4,612 Likes on 2,193 Posts
What is the logic for shutting off the engine when the door is opened with these remote start systems? I've never understood why that is.
Old 03-19-2014, 01:22 PM
Grandpa
I don't understand it either.
If the car has yet to move, then clearly somebody's getting into the car to drive it.
If the car has moved before the door opened, then I could understand.
Old 03-19-2014, 03:14 PM
9th Gear
Pecker's Avatar
It's not really about the logic of safety or security, it has more to do with integration between systems. With the RLX (and all Acuras before), the remote start is an add on accessory that was more of an afterthought. They could not find a way to fully integrate the remote start with the security system.
Now with the new for '14 MDX, the security system and remote start were developed together and have full integration where the engine does not shut off when the door is unlocked or opened.
There are other manufacturers, Dodge comes to mind, that have full integration with their remote start systems.
Old 03-21-2014, 10:58 AM
CFoote's Avatar
I would expect you might see an updated system for 2015. That's my guess. All these platforms are sharing electronics.
Old 03-21-2014, 01:14 PM
2G TLX-S
Edward'TLS's Avatar
Received 1,133 Likes on 813 Posts
Something is not quite right with the 2014 MDX remote starter.
It has been report in the 3G MDX forum that many owners are having operation and ranging problems with it.
Old 03-26-2014, 08:42 PM
beach109's Avatar
I've never seen an issue with the 3G MDX system, aside from user error. It works pretty simply.
The RLX, although it "looks" like the RLX from an electronics perspective uses the older Acura system. This one was originally designed with the turn off feature when door opened for security, but it is a bit annoying to use vs. "normal" systems now. It is nice being integrated with factory components and wiring, however, regardless.
The Acura remote system gives you feedback on the remote to tell you it is running, for how long, etc.
Old 03-27-2014, 02:29 AM
2G TLX-S
Edward'TLS's Avatar
Lucky you. But some other '14 MDX members are not as lucky. Read below thread :
https://acurazine.com/forums/3g-mdx-2014-2020-414/remote-engine-start-problem-891726/
Old 08-17-2014, 11:43 AM
7th Gear
advocate's Avatar
I have had Many Problems with the 2014 Acura MDX (same as 2015) Remote Start. The Vehicle often does not start. Even worse, When I Remote Start it and then follow the User Manual and Car Display Instructions when I enter the Car, of Pressing Brake and the Car Button to get going, the Car Always Dies and Must be Restarted ARGH!!!! Valley Stream Acura (Very Nice) observed this and called Acura Techs who said that this is a Design Problem, and there is nothing that can be done. Buy a 3d Party Starter Instead.
Old 08-18-2014, 04:02 PM
7th Gear
advocate's Avatar
I got it to work.
You have to come in and hold down the Brake and Start Button and hold it down for several seconds. The Car Goes Completely Quiet and the Fan Completely Shuts off, and it looks like it stalled, But it is Running. Remote is Ok, but it almost never operates from inside a house.
Old 08-19-2014, 09:32 AM
I Drive Like A Dick 8≈
Nersh7's Avatar
This is true. The car turns off when you get in it because of the key take-over process. The handshake between the remote starter module and the PTS ignition switch requires the car to shut down to transfer running control. When PTS ignition first came out this was pretty much the issue for most cars that had it, and still with some of the cars (such as the RLX I guess).
Old 11-03-2014, 03:37 PM
neuronbob's Avatar
Thread revival to say:
Ugh. Never mind about adding remote start to my incoming RLX SH. The system is simply too silly to use in the way an ordinary person would use it--turn it on, warm up car, get in car, drive off.
Old 11-03-2014, 07:41 PM
Grandpa
I agree. I'd like to have remote start, but it's not a deal killer, not with a car that drives like this. ;-)
Old 11-04-2014, 06:56 AM
miner's Avatar
The remote start on my '15 TLX does not stop the engine when I open the door; it continues to run. I do have to step on brake pedal and push the start button to allow me to put it in gear..
Old 11-04-2014, 08:17 AM
Grandpa
Perfect!
I wish we could do that, but we just can't. :-(
Old 07-11-2015, 01:50 PM
pcloadletter's Avatar
Is the remote start even compatible with the 2014 hybrid? The instructions show a shift lever. It's standard on the 2016.
Old 07-11-2015, 01:58 PM
Torch & Pitchfork Posse
TampaRLX-SH's Avatar
Received 1,806 Likes on 793 Posts
Yes. The2016 Advance package has the remote start on the SH.
Old 08-12-2015, 04:49 PM
neuronbob's Avatar
It is a dealer-installed option on the 2014 hybrid.
Old 07-25-2016, 08:17 PM
bigred123's Avatar
This was installed on the 2014 hybrid I just purchased ACPO. I find it odd that the car shuts off when I open the door, but searching on this forum found this result and so now I know I'm not doing anything wrong. What the used car salesman said was that I had to carry both FOBs with me (which I found odd). And what was more odd was today (so 2 days after I bought the car!!!) I get a warning message to replace the battery in my FOB on the dash of the RDX. However, it was the remote starter FOB (I replaced the Acura one but still got the message) as the message was removed when I replaced the remote starter FOB.
Does anyone know if I need both FOBs or do I just use the remote starter one that is paired with Driver 1? Don't want to get stuck if I need both!
Thanks.
Old 07-25-2016, 09:32 PM
bigred123's Avatar
OK...I removed the original FOB but the car won't start. It seems silly (and very clunky), but I guess you need both the FOB for the remote starter AND the original key FOB for the vehicle. Going to start weighing down my jacket even more now!!!
R.L. ina TL (02-25-2017)
Old 08-18-2016, 01:14 PM
Option for Remote Start with additional features...
I have to say I use the Remote Start frequently. Especially now in summer to start the car, have it cooled before I get to it. I would expect the cold climate members would similarly appreciate this in winter,
For the RLX models prior to the factory Remote Start feature the aftermarket (including Acura Accessory) remote start devices can be clunky to use and required sometimes awkward installs with extra fobs or keys. I found this product Automatic Pro for $139 that is not only less expensive than an Acura Accessory remote start, but it offers a lot of features / apps that can be managed via iOS and Android devices. It has Homelink like apps, and some car trip / efficiance tracking apps that appear quite extensive beyond the RLX trip computer data. I think a few members here are very diligent tracking trips & efficiency of their RLX. It also has Onstar or Acuralink like capabilities with crash reporting and vehicle tracking. Most of those overlap what Acuralink offers, but with no subscription fee, it appears a good deal. I do wonder if it increases hacking exposure, but feature wise appears impressive.
I have not seen this product mentioned in the forum before and curious of your thoughts?
Automatic Pro => https://www.automatic.com/pro/
Old 02-25-2017, 09:44 AM
R.L. ina TL's Avatar
That awful.
Old 12-11-2017, 05:02 AM
Str8 Rida
LeathaFace's Avatar
Currently debating whether I want to go OEM or aftermarket. I'm researching the difference. On my C300 i went aftermarket w/ the drone system so I was able to start my vehicle from my iPhone. I kind of want that because I reside in a complex and I would need a lot of range to start the car. Is it possible to have Acura install their remote start and I bring in the drone device to add to it? Does anyone have a price range on the remote start install with acura?
I'm really leaning towards OEM because I don"t want to carry the secondary keyfob.
MarQuis2005 (12-11-2020)
Old 12-20-2017, 05:38 PM
Christopher.'s Avatar
I got an OEM remote start installed in my 2018 Acura TLX today - after purchasing the car I negotiated with the dealer to have it installed for free (by threatening to cancel my maintenance contract a few days after purchasing the car, I got the paper that says "Dealer Owes: Remote Start").
You can buy the kit off eBay for about $200 - I would definitely go with the OEM (Acura brand) kit rather than 3rd party unless the 3rd party kit replaces your Acura keyfob and provides some extra functionality beyond what the OEM one does, such as some fancy alarm. I am happy with mine, and, the next time it's below freezing outside (or over 90 degrees heat) I'm sure I will be even more happy.
oyayjoe
01-01-2019 10:17 PM
oyayjoe
09-12-2015 04:40 PM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
jordanboi
09-05-2015 01:33 AM
datadr
09-02-2015 06:46 PM
Quick Reply: Remote Start
