Julius' Airrunner for 2009-2014 Acura TSX
Old 02-01-2017, 09:46 AM
  #41
julius071's Avatar
Originally Posted by Nghi Hoang
Damn, thats scary for real. I planed to go over there and let them work on my brake too. Thank you for ur information.
What a shame because you're not telling us what brakes you're installing!
Old 02-01-2017, 09:55 AM
  #42
julius071's Avatar
Originally Posted by iSeeYouTwo
Really like your trunk setup. Does the 3H not give you the option to "pancake" the car down? (lower front and back at the same time)
Thanks! Spent a lot of time searching for ideas on the trunk setup and I wanted a "functioning trunk" meaning throwing cases of water bottles from Costco and such which I haven't done yet but sadly couldn't fit a check in luggage in the trunk only a carry-on luggage.
I seriously haven't played around with the settings besides the ride preset and getting failure on the height sensors. I don't think Airlift 3p/3h has that feature but yes it bothers me the front lowers faster than the rear granted the front is heavier versus the rear so its logic. But if other Airlift 3p/3h user could chime in, that would be great!
Old 02-01-2017, 10:38 AM
  #43
iSeeYouTwo's Avatar
I'm pretty sure it does have the option I was just curious since I didn't see it used in the video lol.
I want the bracket you used but it seems to be sold out everywhere.
I considered doing a spare tire install but afraid of losing spare tire and then needing it in the future.
Old 02-01-2017, 10:44 AM
  #44
julius071's Avatar
I'm gonna need to dig into the settings and look for that option.
I am assuming you are talking about the "#becausebags Universal Hanging Management Bracket - Flat" https://becausebags.myshopify.com/pr...nt=28175251913 because if you are they're on sale! I've also got compressor isolator kit https://www.bagriders.com/air-manage...lator-kit.html if you want them.
I am already thinking of doing the spare tire setup later in the year.
Old 02-01-2017, 11:29 AM
  #45
iSeeYouTwo's Avatar
Yes I am referring to that one, but...
Old 02-01-2017, 11:58 AM
  #46
julius071's Avatar
Oh wow. Keep in mind these were on sale since November! I figured they would've made a lot of these, maybe boat loads, and keep it in stock.
Old 02-01-2017, 12:13 PM
  #47
Nghi Hoang's Avatar
I'm installed the RL brake
Any thing new on your car yet?
Old 02-01-2017, 12:57 PM
  #48
julius071's Avatar
In for photos!
Just waiting for another shipment from T-Demand front and rear upper arms, tie rod, stabilizer bar and links and that should be a T-Demand complete (unless I want them to make front and rear lower arms), should be here before July if not by June.
Old 02-02-2017, 01:01 PM
  #49
Nghi Hoang's Avatar
I'm still waiting for the wheels,
*Phone quality
Old 02-02-2017, 03:10 PM
  #50
julius071's Avatar
*Phone quality
What part of Seattle you are at.
Old 02-02-2017, 03:16 PM
  #51
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Uhhh... What's up with your brake line?
Old 02-02-2017, 03:28 PM
  #52
julius071's Avatar
Control arm didn't come with a bracket for the brake lines so decided to zip tie it.
  #53
Nghi Hoang's Avatar
I live in Kent area
julius071 (02-02-2017)
Old 02-03-2017, 09:58 AM
  #54
julius071's Avatar
I live in Kent area
Got a few friends that is going to these:
Would be cool if you could join!
Old 02-05-2017, 10:00 AM
  #55
julius071's Avatar
xtcnrice (02-07-2017)
Old 02-05-2017, 10:01 AM
  #56
julius071's Avatar
...Lets talk about wheel offset shall we...
Old 02-05-2017, 10:40 AM
  #57
Rdub81's Avatar
that looks so good!
Old 02-05-2017, 03:03 PM
  #58
Nghi Hoang's Avatar
Of course I will join. I'll contact you
Lol, I just order a set of CF10 wheels, F 19x9 +30 R 19x9.5+30. I need to done some fender work too
Old 02-06-2017, 01:32 PM
  #59
julius071's Avatar
19x9.5 +30 and needing to do fender work?
Old 02-06-2017, 01:34 PM
  #60
julius071's Avatar
Snow!
Rdub81 (02-07-2017)
Old 02-07-2017, 09:53 AM
  #61
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
may rub, depending on tire size
and wow the car looks great even on the stockies!
julius071 (02-07-2017)
Old 02-07-2017, 10:29 AM
  #62
julius071's Avatar
Don't really understand the whole offset and tire combination that is why I asked for ya'll help.
Size of wheels in mind:
Front - 19x9.5
Rear - 19x10.5
And yes I know I will have to roll the fenders and I don't want to pull the fenders.
Old 02-07-2017, 04:08 PM
  #63
iSeeYouTwo's Avatar
I know I've whored these pics out, but they may be of help. This was my old setup 19x9.5 +15 all around with 225/35/19 tires, fenders rolled.
New setup will be similar but 10.5 in the rear.
Old 02-08-2017, 10:08 AM
  #64
Nghi Hoang's Avatar
According to Ed's it's a yes.
My build is the same as his )
Originally Posted by ed_423
stock:
lowered
1. lowered on megan coilovers
- about -1.75" lower in the front, -1.5" lower in the back. i adjusted my height so
many times that these are just rough estimates.
- front and rear are 4 clicks away from the hardest settings.
- in pics it doesn't seem like it's much of a drop, but everything is different once you start driving. so be aware.
2. Forgestar cf10
- 19x9.5 +42 front, with a 3mm spacer = +39
- 19x9.5 +30 rear
- 235/35/19 michelin ps2 all around. SLIGHT stretch. these tires run true to size or run
large, so the stretch is minimal.
3. J-POWER camber arms
- toe is 0, camber is -1.5/-2
4. Fender work needed!!!!
- rear fender shaved, bumper taps shaved as well. NO PULL NEEDED
- front is slightly pulled, however i didn't need it at all!!
5. Review
- This is a semi aggressive set up, took a lot of time and adjustment to make it perfect
for me to daily drive with it. i think i should be able to go softer on the comfort, but
it's not too bad right now. i don't rub at all, have about 1 finger gap all around.
Over all, it's a good set up for daily driving I think, but gotta drive carefully and do a
lot of research before going for a semi aggressive or super aggressive set up.
Old 02-08-2017, 10:26 AM
  #65
julius071's Avatar
In for photos! When your new setup coming in.
Old 02-08-2017, 03:54 PM
  #66
julius071's Avatar
Got new tires!
xtcnrice (02-08-2017)
Old 02-14-2017, 08:51 PM
  #67
SlickxAc's Avatar
your going to want 19x9.5+30 19x10.5+30 if you want to be semi stretched tires. if you want more meaty you will want to have like +40 offsets
Old 02-15-2017, 02:02 AM
  #68
julius071's Avatar
I think I am set with these specs; 19x9.5 +15 19x10.5 +15 as mention in the other thread.
Old 02-16-2017, 09:31 AM
  #69
julius071's Avatar
This is going in next weekend!
xtcnrice (02-16-2017)
Old 02-16-2017, 09:48 AM
  #70
Nghi Hoang's Avatar
Must be niceeee
Old 02-16-2017, 11:17 PM
  #71
SlickxAc's Avatar
car is looking good man! I have been wanting to switch to the 3p/3h setup, but haven't done it yet.
julius071 (02-17-2017)
Old 02-17-2017, 11:10 AM
  #72
julius071's Avatar
Thanks! But long ways to go!
Old 02-19-2017, 05:25 PM
  #73
julius071's Avatar
Old 02-20-2017, 09:10 AM
  #74
julius071's Avatar
UPDATE
There is no "pancake" feature
Old 02-20-2017, 01:36 PM
  #75
jdmaszfcuk's Avatar
how are the height sensors working out with the 1/4" air lines. Bagriders recommended me to switch out to 3/8 lines. I was trying to calibrate in pressure mode because I don't have sensors installed yet. I have 1/4 " lines but it was just going up and down in the front for about 10 minutes and then failed
Old 02-20-2017, 01:47 PM
  #76
julius071's Avatar
Bought my setup from Bagriders and was not suggested to run 3/8" lines. I ran the calibration and was stock at step 16 of step 16 and ten minutes then failed as well. I called Airlift and they said my sensors still needs to be slightly relocated. So right now I am running with pressure.
Old 02-21-2017, 10:07 PM
  #77
jdmaszfcuk's Avatar
Mine was stuck at step 11 out of 16 . I hope with the height sensors installed it's good
Old 02-22-2017, 07:52 AM
  #78
julius071's Avatar
Try to reset your manifold. To reset your manifold, simply unplug the main harness for five minutes and plug it back in after five minutes. I got this advice from Bagriders. If that fails then you need to relocate your sensors. Do you have photos of where you mount your sensors and your rods too? I would want an idea where it is.
Thanks!
Old 02-22-2017, 08:16 PM
  #79
jdmaszfcuk's Avatar
Thanks!
I didn't install the sensors as yet
Old 02-22-2017, 08:48 PM
  #80
julius071's Avatar
I thought you went through the calibration process and failed at step 11?
Quick Reply: Julius' Airrunner for 2009-2014 Acura TSX
