car rev wierd
Old 09-12-2009, 11:38 AM
Always a Honda =Þ
JterrorC's Avatar
car rev wierd
im at a light car seems like somones pressing the gas n letting it go repeatedly..i drop it in neutral...rev goes to 2500 den drops..n keeps this on forever......what to do?....
Old 09-12-2009, 11:40 AM
J23
J23's Avatar
check your idle control valve honda motors are notorious for this.
Old 09-12-2009, 11:51 AM
J23
J23's Avatar
theres an easy way to check this, remove your air intake duct from the throttle body, start you car and let it idle ( this should be done when the engine is cold) there are 2 holes in the throttle port the top one is for the idle air control valve (IAC), the bottom if for the fast idle thermo valve (FITV). plug one of the holes with your thumb. if the idle goes back to normal when you plug a hole replace that part (top hole IAC, bottom hole FITV) NOTE: these parts arent cheap, sorry bro.
Old 09-12-2009, 04:37 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Its your IACV. Take it off and clean it.
Old 09-13-2009, 02:47 AM
Ya....It's an Acura
ftLauTL's Avatar
bingo
Old 09-13-2009, 09:24 PM
Always a Honda =Þ
JterrorC's Avatar
thanks everyone ill take a look at it...even tho the revs stopped on its own..
Old 09-14-2009, 07:26 AM
fsttyms1's Avatar
stopping on its own means nothing. What it did was because of the IACV. Do a Search on it and see. Take yours off and clean it up.
Old 10-19-2009, 05:01 PM
Always a Honda =Þ
JterrorC's Avatar
questions:
so if you look at the two hoses under the carton....one pointing up and one pointing left....
so once i disconnected the left lookin one...liquid came out...im thinkin rusted water....cuz it stunkd like old pipes... is this normal...or is my cia suckin in water?? ... they both look wet...n a huge stench came out of those hoses....
what do i do?
now you're looking at the accel cables....see the srcews...how am i suppose to get those out...my grip pilars dont fit...n a phillips wont work....stupid thing is the bald one came out with ease..but the good one is stuck....ive hit it with several tools hopin it lets som stress go..but still not budging.. i gave up n jus flipped it around with the cable on...
now the iacv screws are stuck even worse...i dont wanna strip it..any ideas?
Old 10-19-2009, 05:22 PM
fsttyms1's Avatar
First the hose with liquid in it is coolant and should NOT be hooked up to a cai.
Dremmel and make a straight cut on it and use a flat head.
Old 10-19-2009, 05:30 PM
Always a Honda =Þ
JterrorC's Avatar
good idea....on the flat head cut....keep it in mind for next time..but finally got it out...NOT the cable but the iacv....here are pics.... ill clean it out in tact...if not then ill use your idea for the five star screw...and now that i opened it..i c its NOT connected to the cia...its its own port....i thought water went the hole in the throttle...
is this REALLY dirty..or normal grime....and special thanks to the hammer that slipped n slammed on my thumb..
screw wont budge....can i jus clean EVERYTHING on this pic let it dry dne put it in witout disassembling it
Old 10-19-2009, 06:41 PM
Always a Honda =Þ
JterrorC's Avatar
damn i really want to clean that spindle on the inside of the black housing....i cant drive now soooooo i cant go to any store....cant do that flat head trick....anything else?? ... pliers are just not gripping....
Old 10-19-2009, 07:01 PM
Avant Garde Wheels
jjashaa's Avatar
that is one freakin dirty throttle body..
i had this problem but it went away..
it was during the type-s IM/TB swap
Old 10-19-2009, 07:26 PM
fsttyms1's Avatar
Soak the lower part in carb cleaner. Then put a dab of wd40 in that area to lightly lube it
Old 10-19-2009, 07:57 PM
Always a Honda =Þ
JterrorC's Avatar
thanks....installed...drove around the block couple times fine....lets see tom. after the highway....
Old 10-28-2009, 07:05 PM
Zenica's Avatar
I have a question along these lines.
I parked my 99' TL for 3 weeks and when i got back, the battery
was as dead as a door nail. Turns out the RR door was ajar and drained
the battery dry.
I had to give it a 10 minute charge off of another car and then use that car
with the engine running to get the TL to start. When it did, it had a mean
hunting idle (up/down--repeatedly) but it went away after driving it for an
hour on I78. Before it is suggested, I cleaned my IACV about 6 months ago
when the weather was nicer than it is now.
The hunting idle is gone but why did it do this in the first place?
Old 10-28-2009, 08:51 PM
fsttyms1's Avatar
the battery dry.
The iacv was probably stuck a little. It happens to many who park the car for a while.
Old 10-29-2009, 06:29 AM
Zenica's Avatar
I was hoping it would be something as simple as that.
Not that the IACV was a tough job but with old man winter on the way
I wouldn't look forward to working on the car, heated garage or not.
peti1212
ILX
22
01-05-2022 05:14 PM
02-25-2020 09:57 AM
Mike Bertram
09-10-2015 09:27 AM
Phambam12
09-06-2015 06:57 PM
jordanboi
09-05-2015 01:33 AM
Quick Reply: car rev wierd
