Using Torque app as boost/EGT/etc gauges and scantool
Old 05-09-2012, 07:48 PM
PM me if you need a reply
InfamousJamous's Avatar
Great Android app, I just had to recommend it. Connects any vehicle's OBDII port via bluetooth adapter. It also works as a scan tool. I had a check engine light on and this thing allowed me to check the fault code/detail and clear the code.
Torque Lite (free) https://play.google.com/store/apps/d...owl.torquefree
Torque Pro (paid) https://play.google.com/store/apps/d...e=related_apps
Bluetooth adapter
Amazon Amazon
I'm looking to get a cheap 7" tablet to mount in my RDX. At the moment I'm using the app on my phone which is mounted in front of the speedometer (screenshot below).
The Torque app shows the following info on my 07 RDX:
-Air fuel ratio
-Barometric pressure
-Exhaust gas temp (catalyst temp)
-Engine coolant temp, load, RPM
-Fuel level
-Intake air temp
-Intake manifold pressure
-Mass air flow rate
-Pedal/throttle position
-Speed (GPS, OBD)
-Timing advance
-Voltage
-Volumetric efficiency
-Acceleration (x, y, z axis)
-Time/Distance/GPS (0-60, 1/4 mile)
-Power (hp, tq)
-MPG
The boost, AFR and EGT gauges are invaluable. The EGT gets up to 1500 degrees on boost and helps me know how long I should let the turbo cool down before I turn off the engine.
More values can be added via Honda/Acura extended PIDs. I'm looking to add accurate transmission temp, fuel pressure, oil temp/pressure values so if anybody can help please let me know. Thanks.
Old 05-09-2012, 08:06 PM
tommystyle86's Avatar
what adapter do you need to buy?
Old 05-09-2012, 09:27 PM
JCRDX11's Avatar
He had it on the first posting -
Bluetooth adapter http://www.amazon.com/BAFX-Brand-BLU.../dp/B005NLCGF8
tommystyle86 (05-09-2012)
Old 05-10-2012, 12:14 AM
DRR98's Avatar
IJ, nice set up. I'm using rev. No egt or afr. Email to rev- I want egt and afr.
Old 05-10-2012, 07:13 AM
2008 Acura RDX
wspy's Avatar
So I'm assuming that this dosent interfere with the phone BT operation?
Old 05-10-2012, 02:29 PM
DRR98's Avatar
https://acurazine.com/forums/1g-rdx-performance-parts-modifications-162/aftermarket-guages-811543/
Some info here.
Old 05-10-2012, 09:44 PM
JCRDX11's Avatar
Doesn't effect the phone bt when I am using the app.
It will stop the app and go to the call instead.
This is the adapter that I use - Vgate v1.5 MINI ELM327
http://www.ebay.com/itm/Vgate-v1-5-M...t_10870wt_1163
Old 05-11-2012, 06:48 AM
DRR98's Avatar
With my rev/iphone set up, w/gauges on get a call it switches to bt-hfl. When the call ends the home screen for rev is displayed. You have to tap the button to go back.
I have tried to post data here but the format is jumbled after I paste it.
Old 05-11-2012, 01:18 PM
Originally Posted by DRR98
Good stuff, thanks. I must have missed that.
I would think that the ECU knows the oil pressure/temp so we can pull the readings via extended PIDs instead of adding sensors, but looking at the parts diagram for the oil pump I don't see any sensors.
Fuel pressure and tranny temp would be more useful IMO.
I got a 7" tablet and mounted it above the stock display. Screenshot below.
I don't have the Tech pkg so I can't comment on using it with the OEM bluetooth. I use the Scosche bluetooth AUX plug instead for audio/phone (another device I recommend
Amazon Amazon
Old 05-11-2012, 01:56 PM
exist12's Avatar
nice layout
Old 05-11-2012, 02:33 PM
Thanks.
I posted the Scosche unit without bluetooth A2DP audio. Here's the correct link to the Scosche bluetooth unit that plays audio:
Amazon Amazon
The Transmission temp is showing a reading but the values are identical to the Coolant temp so I don't think it's working correctly.
If anybody knows info on Honda/Acura extended PIDs, then that could help us pull more data like VTEC, current gear, etc.
Old 05-11-2012, 10:58 PM
2008 Acura RDX
wspy's Avatar
Would love to see a pic of the tablet mounted in the car
Old 05-12-2012, 09:13 PM
Just changed the engine oil, ATF/rear diff, and went for a test drive..
Old 05-12-2012, 09:35 PM
2008 Acura RDX
wspy's Avatar
Is that a suction cup on the screen?
Old 05-13-2012, 03:33 PM
DRR98's Avatar
I emailed rev Friday, no reply. Any chance '11 and later have no egt or afr sensor?
Old 05-13-2012, 08:29 PM
not an SUV ...a Big Hatch
BigHatch's Avatar
thats nice IJ... curious to see before and after intake temps with an intake manifold gasket. it'd be good for that purpose alone!
Old 05-14-2012, 12:38 PM
DRR98's Avatar
I agree that gauges are a much needed mod for the RDX, and I'm still working on adding more.
^BH - I'm not sure if you could compare iat before and after the gasket because the iat is affected by so many variables.
If the ambient air temp and rh and bp are all exactly the same, engine load and so many more variables all still factor in as well.
May see the before and after gasket diff/temp the most in sustained boost runs where the heat would build up much higher.
Heat soak?
Either the track or long uphill mountain roads?
I'm still trying to understand how IJ is getting what I can't have.
Whaa!
I tried to find a egt sensor on an '07, don't see it.
Is this maybe a virtual sensor using the pid feedback from some points to estimate egt temp?
Either way, me want go there.
Sniff...dabs tears...
Old 05-14-2012, 01:37 PM
DRR98's Avatar
Oil T & P
Looking at the '11 block - # 3 (20mm) and 4 (28mm)...
What are they for?
Are these bolts sealing oil or coolant?
If oil, could t&p sensors replace these bolts?
Old 05-14-2012, 01:44 PM
Yes.
Amazon Amazon
I'm working on an ice box for my K&N short ram. Maybe I'll try out the intake manifold gasket after. It seems easy to replace as I don't see any coolant jackets.
I'm getting my EGT and AF readings from the A/F sensor. If I had the secondary O2 sensor installed I'd get readings from that too. The values are there, your developer just needs to add them to the app. Are you able to add extended PIDs in that app?
Heat soak?
Whaa!
I get major heat soak with my K&N short ram. At highway speeds the intake temp would be 90, but at a stop light after some hard runs the temp can go up to 140.
The sensor name I'm getting my EGT readings from is "Catalyst Temperature (Bank 1,Sensor 1). Maybe that'll help your Rev dev.
What are they for?
#3 and 4 seem like oil seals
#12 seems like some kind of oil pressure switch
#11 is a knock sensor and we need that reading via extended PID!
Last edited by InfamousJamous; 05-14-2012 at 01:59 PM. Reason: Consolidated replies to quotes
DRR98 (05-14-2012)
Old 05-14-2012, 02:23 PM
DRR98's Avatar
Thanks!
Thanks so much for the help IJ, first I need to complement your sweet set up.
I'm slaved to apple compatability, so I drool over a maxi-pad and mount. Some day.
brought to you by: Apple Maxi Pads
I'll keep working on devtoaster to wring it out.
I remember they had a help forum that I need to find again?
Old 05-21-2012, 08:39 AM
DRR98's Avatar
So Rev2 Hi-$ iphone App Sucks Dog Balls? Time to bail?
Still no reply to emails to devtoaster, the developer for rev.
I'm in for $200 for the transmitter and $50 for the app.
I need to re-think my drink.
IJ,
Nice. Looks like you are displaying ~ 20? Is set up easy?
Below is from the wifi transmitter mfg PLX backing up what you had said before...
Hello,
I have an '11 Acura RDX using plx kiwi-wifi + iMFD. For now, no inputs to iMFD. I am using the Rev2 app on iphone 4s.
Another owner of an '07 RDX is using android phone and torque pro app via bt.
He gets readings for afr and a temp reading for Catalyst Temperature (Bank 1, Sensor 1) standard with his setup.
With my setup I see no afr and no temps for any exhaust points.
Can these points be displayed in my setup thru more work or upgrades by the developer? (w/o input to iMFD)
Thanks...
...by PLXSupport_DF » Wed May 16, 2012 12:49 pm
Unfortunately, Rev2 does not support custom PIDs. It is possible to add support for additional PIDs if the developer chooses to do so.
There may be other iOS apps that offer those PIDs and customizable PIDs, which would allow for reading that data if that information is available from your vehicle
Old 05-21-2012, 02:15 PM
Yes, setting up Torque is easy and there are lots of advanced options. You might want to try Torque and get a dedicated device like I did.
The developer for Torque (Ian) has responded to all my e-mails within a day. He also has a website and forum dedicated to the app at http://torque-bhp.com/.
Torque (paid) only costs $4.95 (Rev costs $39.99)
The bluetooth adapter is only $23.99
Most 7" Android tablets (Nook, Kindle Fire, Samsung Tabs) are $250 or less.
(Beware of Samsung as their bluetooth drivers are modified and have issues. Samsung says they are aware of the issue and will release a fix. I have to pair my Galaxy Tab 2 7.0 each time but it's so worth it.)
My current setup:
Old 05-29-2012, 10:18 PM
DRR98's Avatar
I found an apple compatible interface called dash command.
Rev has nicer looking gauges and was simple.
DC has ext pids- egt, afr, no fp. I'm trying to get the gear ind to function.
Old 06-26-2012, 01:34 PM
Update:
My new setup. The tablet was redundant as I had to maintain/charge multiple devices. I have since used my HTC EVO LTE phone and mounted up higher.
Old 06-26-2012, 06:54 PM
DRR98's Avatar
Just the essentials, nice set up. Fills up your pocket a bit?
InfamousJamous (06-27-2012)
Old 06-27-2012, 02:32 PM
You know it.
Old 11-18-2012, 08:59 PM
camaroracer016's Avatar
My current setup:
Do you think you could post the config file for your display layout? I really like it and I'm too lazy to set it up from scratch lol
Old 06-11-2013, 09:34 AM
andygirl's Avatar
The adapter mentioned at the beginning is not available on Amazon.
Old 06-11-2013, 10:24 AM
user65's Avatar
This is the one I got:
Amazon.com: Soliport ELM 327 Bluetooth OBDII OBD2 Diagnostic Scanner: Automotive Amazon.com: Soliport ELM 327 Bluetooth OBDII OBD2 Diagnostic Scanner: Automotive
Old 06-11-2013, 10:48 AM
user65's Avatar
^ This scanner is kind of big, I've already kicked it twice when going for my ebrake. I'm tall and have big feet, so this might not be a problem for others. But I use my ebrake every time I park the car so it's kind of a pain to be careful each time I set the ebrake.
This one looks much smaller, I may try it out.
Amazon.com: V1.5 Super Mini ELM327 Bluetooth OBD2 OBD-II CAN-BUS Diagnostic Scanner Tool: Everything Else Amazon.com: V1.5 Super Mini ELM327 Bluetooth OBD2 OBD-II CAN-BUS Diagnostic Scanner Tool: Everything Else
I'm using the first adapter I posted above ^ along with a jailbroken iphone and dashcommand. You have to get roqybt4 and obd4(included with roqy which is $6) in order for your iPhone to see the bluetooth adapter. So in the end it's a $70 solution for getting instant readings from your car.
Sometimes it's spotty, but for the most part it works. I'm going to end up getting a DM6 combo from PLX to have a consistent true AFR reading though.
Old 06-13-2013, 10:04 AM
Turbocoop's Avatar
I know this thread is pretty old but Im trying to choose which one to get because apparently its just luck of the draw with these things... If anyone has experience with one of these and the Torque app please post which one you got. If not I might just buy a couple and see which one works best.
Old 08-27-2013, 01:44 PM
5th Gear
ruskiesrule's Avatar
OBDLink MX Scan Tool
Check out OBDLink MX Scan Tool here:
http://www.scantool.net/obdlink-mx.html
Its $150, but WELL worth the money, its has very fast refresh rate on the PID and just plugs into your OBD2 (no wires or bumping with your knees). I just leave mine plugged in all the time. Their battery-saver feature allows you to leave it in without danger of draining your car’s battery.
You can also download their free OBDLink Android app here:
https://play.google.com/store/apps/d....OBDLink&hl=en
I can read code, clear them, run diagnostics, setup a dashboard, a map that records your speed of travel, and monitoring of pid's with data logging. Pretty handy tool all-in-all!
Old 09-07-2013, 03:05 PM
Here's a screenshot of my current setup. I modified the colors to match the RDX guages.
I'm not sure if I'd pay $150 vs $20 for a bluetooth OBDII adapter. The one off Amazon is fast enough for my usage.
The Torque app is worth every penny. I've gotten my money's worth for sure.
I use a magnetic mount for my phone which looks great and works well with my Samsung Note II. No need to mess with clamps and it mounts in any direction. The suction cup is also sticky so it sticks to the textured dash on the RDX.
Amazon.com: iMagnet Cradle-less Magnetic Mount with Quick-snap Technology, Smartphone Car Windshield Dashboard Universal Holder: Cell Phones & Accessories Amazon.com: iMagnet Cradle-less Magnetic Mount with Quick-snap Technology, Smartphone Car Windshield Dashboard Universal Holder: Cell Phones & Accessories
Old 09-08-2013, 12:33 AM
FLETCH
TheWrench116's Avatar
that's awesome!
Old 07-18-2015, 07:41 AM
#ForcedInductionFamily
WRXtranceformed's Avatar
Reviving this thread a bit. I just picked this up on Amazon and couldn't be more pleased:
Amazon link:
Amazon.com: Panlong Bluetooth OBD2 OBDII Car Diagnostic Adapter Check Engine Light for Android - Compatible with Torque Pro: Automotive Amazon.com: Panlong Bluetooth OBD2 OBDII Car Diagnostic Adapter Check Engine Light for Android - Compatible with Torque Pro: Automotive
It's surprisingly small, here it is next to my key in comparison:
Tried it last night on my XFR and it works great. It's also so small that there is really no danger of bumping it with your leg, in fact it sits up in the OBD plug area out of sight. I've got to rearrange the gauges on TorquePro on my new phone and set it up for our RDX as well. For $13 you can't go wrong! Important to note though, this does not turn itself off with the car so make sure you unplug it after use.
I'll try to get a profile set up for the RDX and take some pics on our day trip today. At some point I might hook up an old Nexus 7 we have as a display in it but I'm not that worried about it because my wife won't really need to be using it much.
Old 07-19-2015, 08:59 AM
I ended up driving there and back yesterday so I didn't get to play around much with the interface but it works smoothly and beautifully on the RDX. Here are a few of the default outputs that I tweaked around a little:
Here is about halfway how I would want it to look after playing around with it while drinking my coffee this morning (unconnected to ECU, so I'm not sure if it will read oil temp or not):
That's displayed from my Galaxy S4, so I've got room for two small sized gauges on the "home" screen. If I end up installing one of our tablets obviously I could play around with the larger ones. Just need to plug it back in and figure out two more parameters that I want to measure on this car....I would love to get EGTs but I'm not sure if I can get them off of this car either. Once it's 100% dialed in I'll have to post back up again. Definitely a worthwhile investment though!
Old 02-15-2017, 11:38 PM
Current setup
Attached is the theme file if anyone is interested. The extracted folder goes in the hidden ".torque" folder on Android devices.
Attached Thumbnails Using Torque app as boost/EGT/etc gauges and scantool-s.png
File Type: zip
knight rider
03-04-2016 08:59 AM
CL-S progression 01
01-26-2016 04:15 PM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
Quick Reply: Using Torque app as boost/EGT/etc gauges and scantool
