Climate control diagnostics mode
I have an 07 RDX and have searched and come up with info for MDX and TSX and such but not RDX. Maybe I didn't search correctly. I wanted to know how to enter HVAC diagnostic mode and the table of error codes. Neither my driver or passenger side temp controls do anything. Wanted to fix it before winter comes so I can have heat. Blend motor on drivers side doesnt respond to temp up or down...gavent checked passenger side but air temp doesnt chahe there eithet.
Thanks!
Thanks!
try this, msg#47
https://acurazine.com/forums/1g-rdx-.../#post16602520
I prefer to search using "advanced", I can the restrict the forums searched, etc.
Hope this helps!
CSmoney28
Please check all of the fuse boxes including but not limited to both under the hood on the driver side as well as the one under the drivers side dash board. Get a fuse remover tool and new fuses. Look on the Acura parts store if you need a diagram of anything. Under the fuse cover should show you what each fuse does. Let me know if you need help...
Redryderm
04-15-2017 02:47 PM
Rod406
1G RDX Problems & Fixes
10-08-2011 04:50 PM
