My Zulu Delta X-ray
The following 2 users liked this post by robpp:
Acura TL Builder (04-16-2021),
justnspace (07-21-2018)
justnspace (07-23-2018)
Transmission 3 x 3
Fill Plug washer 24 mm. 17mm head.
Drain Plug washer 18mm head 3/8 square
Mine took about 3.5 each time.
Drain Plug Magnetic
Fill Plug
First one used NOS label
First drain
Second Drain
More Fluid New Label
Number 3
Transfer Case Drain and Fill
Fill Plug 18mm crush washer 3/8 square plug
Drain Plug 18mm crush washer 3/8 square plug
Fluid for Transfer Case
Drain Plug Magnetic
Fill Plug
First drain
Second Drain
Number 3
xtcnrice (08-20-2018)
But TBH not too much else going on over here.
ZDX is even more rare than a Wagon : thumbsup:
Today I changed the oil and put the OEM rear bumper applique on. Was a big day LOL
Bought the replacement door panel
Color is correct
rear bumper protector
Oil filter wrench and drain plug wrench
New 14 mm crush waher
Cargo area led
FilTech A01 OEM HONDAHOND FILTER
Mobil 1 5w-20
Proper wrench 65-67/14
Mileage is 68050.
new car inspection said needed new sway links to resolve slight jiggle noise
Rock Auto Moog Problem Solver
$52 for pair delivered.
Remove need 6mm Allen and 17mm wrench.
These aren't for everyone as they require grease service every once in a while.
install is 18mm socket and 19mm open end yo hold shaft .
Then some grease and I had some rubber caps that don't fit right but on until I get something better
I think the rear ones are next, slight rattle in the rear when going over something like railroad tracks, just haven't had a chance to check them out.
Christ almighty,
firstly, you know your fuckin maintenance...gonna assume you're a tech or were in your past life.
Secondly, damn right for loving the ZDX. I had one as a loaner long ago and although it's not for everyone, it's a
futuristic spaceship that you rarely ever see...cargo space is no worse than my vagon so technically it's practical
as hell for what it is.
I'll definitely be following your progress!
Christ almighty,
Christ almighty,
Im a car guy that refuses to pay the stealer for anything I can do myself. An early purchase was a service manual set. Worth every penny.
And Im just a backyard mechanic at best. But I do enjoy the wrenching, had many hot rods, classics, Harleys, etc over time.
Lastly, Im OLD as dirt//
ZDXFTMFW
Today I paid to have the brake fluid flushed. Wanted them to look at the noise in the front suspension
i replaced front and rear sway and some noises went away but not all
Said the found a loose front left lower control arm.
And same wheel, the metal clips that holds brake pads was missing. Pads were flopping around.
Noise gone.
And check off my last maintenance item:
Brake fluid DONE
Noise gone.
Brake fluid DONE
LC-TL2002 (10-14-2018)
More maintenance:
New Honda Wiper Blades. Had some crap arms.
And I bought an extra set of rubber blades for next time.
Next up some Clear .040 LaminX to protect the fogs. I removed the Yellow film, added Yellow LEDs prior.
And I haven't installed this yet....need to consult the manual, but this b pillar piece was damaged when purchased.
The following 3 users liked this post by robpp:
robpp (05-16-2020)
justnspace (08-05-2020)
88,000 miles last week. At 87 I did a trans drain and fill one time and transfer case fluid. Cabin filter.
One note: I LOVE the Stoptech brakes I installed the spring of 2020. Great stopping. Nary a bit of dust after weeks of driving.
Got some creaking when I back out onto the street, I am thinking front strut mounts, front struts, sway bar bush. Rear struts.
With standard suspension, what are the choices for new struts? Looks like OEM is no more?
It would make sense for them to.
I used to see them around, had one for a loaner.
I did not like that it was tiny for an SUV...hitting my head on the
way in and our LOL...but if you can get past that, it was a cool
futuristic looking thing.
