Where in the world is the cabin filter..?
Old Feb 19, 2013 | 07:50 PM
VeNeNo's Avatar
El Chulo...
Question Where in the world is the cabin filter..?
Hey whats up ZDseXer's I have changed many a Honda and Acura cabin filter on my own in the past. For some God forsaken reason I can't find the location of the filter in our beloved ZDX. If anyone has changed theirs or just happens to know where it is located please fill a brother in... (and for all the haters lurking in cyber space, I have already checked the owners manual. It states to see your dealer for that service)...
Old Feb 19, 2013 | 08:15 PM
drivinginmy04tl's Avatar
I believe it is in the glove box behind the shelf that the manuals go in. I have not tried yet but that is where it is on allot of the newer Acuras. You can pull out the shelf piece and there should be a door panel with a plastic tab on each end. You remove that and the filter slides out. I may be wrong but that was how it was on my TL.
Old Feb 20, 2013 | 12:03 AM
Sandro's Avatar
correct
Old Feb 20, 2013 | 06:38 AM
TLtrigirl's Avatar
3G TL/2G MDX Owner
open glove box.
empty glove box.
squeeze the two sides of the glove box inward and let the glove box drop down.
there you will see a little black box with end tabs.
push end tabs inward and slide the cabin filter out.
replace cabin filter.
reinsert and reverse the above instructions.
done. less than 60 seconds of your life was spent replacing your cabin filter. enjoy!
and the dealer wants an absurd amount of money to do this for you.
Old Mar 3, 2013 | 05:29 PM
VeNeNo's Avatar
El Chulo...
Thumbs up and then there was light!
Thank you guys and gals!! I found the cabin filter. It is in the glove box but not like the traditional honda/acura pinching glove box and lowering. You have to pull out a plastic divider that is in there and then viola! Its behind that piece. I was afraid of pulling it to hard at first and possibly snapping the plastic shelf, but a job well done none the less. Cost me a total of $9.
Ivan-1
Dealership-0
Old Mar 3, 2013 | 05:35 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
ugh...they designed the ZDX like the TL. WTF? the one in the 3G TL....you have to take the glove box off completely, then pry off the trim piece to access the cabin filter (hoping and praying you dont' snap any important clips that hold it on). i think i might do the "mod" and cut an access into the plastic to get to the cabin filter easier.
the honda engineer that designed it this way...
glad you found it though!
Feb 25, 2020 09:57 AM
vpasla1
Sep 17, 2016 07:24 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
LeVeL
Oct 18, 2015 04:19 PM
merc009
Sep 29, 2015 03:06 PM
