Another Fitment Q...
Perhaps you guys can school me, as a lot of you have done a wonderful job of fitting your Z's with new rims.
Running the stock 19's now with 255/50r19.
If I find a wheel that is 5X120 and 8.5 width, what other numbers do I have to be concerned with?
Let's say I find a wheel with those specs, and a offset that is significantly different, say 30mm less. I am assuming that means it's going to stick out 1 extra inch, yes? Is that really a big difference? And with the fender height of the ZDX, should I care? Are there any issues with that, or does something else need to be done in concert with that? And does bore factor in?
Any help you could give would be amazing...
the offset determines if the wheels fit farther outside or towards the inner of the zdx which may cause rubbage against your fender. if you ran a offset 30, you may need a 5 mm spacer as the range of offset for the zdx is 35 to 45 I believe. if you bought a rim with a different center bore than the zdx, you will need to use hubcentric rings so there is no vibration. lastly, you need the right tire size as you need to be within 3% of the 255/50/19 overall diameter. check out tire size calculator from 1010tires...
MrHeeltoe
79
10-14-2015 08:47 AM
adreano17
09-29-2015 08:48 AM
nuldabz
09-03-2015 05:49 PM
