Acura ZDX staggered wheels
Hi, I’ve just recently purchase some staggered wheels for my ZDX. I’ve took it to the local wheel shop and they said it was a bad idea to put staggered wheels on AWD, unless it has the same circumference on all four wheels. Has anyone put staggered wheels on SH-AWD?
These all the wheels and tires specs I’m putting on.
front - 22x9
rear - 22x10
picture attached for the tire sizes. Thank you, any input will help.
The circumference is off by .1 of an itch.
front - 22x9
rear - 22x10
Graphite Ghost
this is pretty much the rule. you try and match the circumference with different sizes front and back.
I used to have 255/50 19 on my on 19.8
lets say you want to use a wider wheel in back. 20x 8.5
255/45 20 would work on the rear.
the circumference is what needs to match or be very close
my example its 0. perfect match.
Gcode (01-02-2021)
