WTH is this????
WTH is this????
I used Mother's Tire and Wheel foam and this is what I ended up with. I can't seem to get it off. Any ideas? This white haze is on at least two of the wheels now.
Those of you who will beat me up for using that product, I get it. And, the wheels were not hot.
![](http://kvg.smugmug.com/Other/Camera-Awesome-Photos/i-hz5sRBG/0/M/image1-M.jpg)
If i am not mistaken Mothers Tire and wheel foam is a cleaner,it may have cause a reaction on the clear coat of the rims.
Regardless of the cause,i would say that you have an issue with the clear coat.
This may sound strange, but how about using a clay bar on the wheels with the haze......and then wash and apply wheel wax to them?
Mothers has some good car care products on the market, too bad it did this tho.
I could be wrong but looks like residue from the product. I'd try Turtle Wax bug and tar remover or nail polish remover.
Last edited by TeamAcura; 06-16-2013 at 09:46 PM. Reason: Fixed, Hogan caught me slippin' lol
Well if you had to purchase a new one ...about 276.16 so not god awful. I believe I picked out the correct rim. FYI
Then I guess you could to try to use it as a spare in trunk (if it fits)
(Use the vin and to get the right model (chassis >wheel disk ))
http://acura.bernardiparts.com/Searc...acura-tl-parts
3G TL/2G MDX Owner
you could try the claybar see if that works. if that doesn't work, you can try an all purpose cleaner for cars.
it either looks like residue from the product or some sort of clearcoat reaction. odd. i can't imagine mother's products doing something like that.
you should be careful with some of the tire dressing products out there since they can actually dry out your tires (contribute to dry rot and early weather checking). certain ingredients contained in the products can leach out the rubbers natural oils/moisturizers that the manufacturer has added to the compound to improve the life of your tires (from a UV/cracking/dry rot) point of view.
you may want to switch to aerospace 303 (which has a multitude of uses-dash, tires, engine covers) and contains UV protectants. i sound like an infomercial. sorry about that.
see what the autogeek guys have to say and let us know. i'd be interested to hear what they have to say.
Did you wax your wheels?
Kinda looks like wax residue. If it was wax, I would try to reapplying wax on it again and try to remove.
If not wax and it is some kind of reaction with the clearcoat, I would try to polish that out. Try Meg's Ultimate Polish first and if that don't work, move up to Ultimately Compound. Will need some elbow grease.
Stay away from nail polish remover. And matter of fact wheel cleaners .. they aren't needed unless you really neglect your wheels. Nothing more than the end of the car wash soap and a dedicated mitt needed.
Dressings won't rot the tires .. some cleaners may aid in drying them a bit but the dressing will replace it.
Not to be a turd but I'd like to see the basis for this .. "you should be careful with some of the tire dressing products out there since they can actually dry out your tires (contribute to dry rot and early weather checking). certain ingredients contained in the products can leach out the rubbers natural oils/moisturizers that the manufacturer has added to the compound to improve the life of your tires (from a UV/cracking/dry rot) point of view."
Most of weathering and checking is from a commination of lack of the rolling and sun exposure. The rolling releases the carbon black in the tires which serves among other things as a UV barrier. That's the off black/brown stuff we see run off our tires when we clean them. Be it by itself or mixed in with the dressings we use. Spray on foam dressings are a good example .. they not only capture the carbon black being released but collect brake dust and other dust.
Sorry OP .. went off topic.
Says in essence not good for uncoated aluminum.
3G TL/2G MDX Owner
http://www.tirerack.com/tires/tirete...jsp?techid=30&
http://www.bobistheoilguy.com/forums...Number=2052924
clarification: silicone based tire dressings are the culprits. however if one goes through tires like shoes, then not a big deal.
just a couple of sources:
First one holds a little merit but you will notice it says "excessive use of tire cleaners/dressings that inadvertently remove some of the tire's anti-oxidants and anti-ozone protection during every cleaning procedure" Most dressing by themselves don't remove anything.
The second reference thread is a bunch of unsubstantiated hearsay . Sort of like the Armorall on the dash of years gone by
nj2pa2nc (06-17-2013)
Mothers® Wheel & Tire Cleaner is a foaming, non-acidic spray, formulated to quickly and easily clean both wheels and tires, including blackwalls and whitewalls. Safe for painted, clearcoated, color coated, steel, modular, chrome, or factory coated wheels and hubcaps
Sorry for the confusion.
So, I posted this problem to the forum at autogeek.net. Linked below.
http://www.autogeekonline.net/forum/...tire-foam.html
After a few helpful replies from others, I received a reply from a representative from Mother's who asked me to contact him directly and send more photos.
I did that less than 20 minutes ago. He sent the photos on to one of his chemists who has since responded via email stating that if the wheels had been refinished (which mine were by the dealer before I took delivery), then the refinish is not as hearty as the OEM and can realize issues such as this with strong cleaners like their Tire and Wheel foam.
He is sending me several of their products to use to resolve the issue as well as wheel cleaner that is "more appropriate for my car."
I thought this was a great example of customer service. I hope their products work to resolve the issue. I will let everyone know when I try them out.
TLtrigirl (06-18-2013)
Props to Mother's for sending me all this stuff to make me feel better about their products.
-2 big packages of micro fibers
-clay bar kit
-back to black tire renew
-rubber vinyl protectant
-Carnauba wash & wax
-wheel cleaner
-powerball mini speed polisher
-Powercone
-leather tech foaming wash
-plastic polish
-scratch remover
-leathertech moisture infusion gel cream
-4 gallon bucket with lid
WOW...that's customer service!
-clay bar kit
-wheel cleaner
-Powercone
-plastic polish
-scratch remover
![](http://kvg.smugmug.com/Other/Camera-Awesome-Photos/i-tKJZJ7G/0/M/CA_06291309465943-M.jpg)
mr2core (06-30-2013)
Its only customer service if one of the things they sent solves the issue .. otherwise its damage control. Leather conditioner isn't going to fix your wheel.
Regardless, in the age of no customer service, this is over and above what most companies would do. They could have said, our product just didn't cause that and move along.
If it doesn't resolve the issue, I will move along in the process of working with them to resolve. In the meantime, I have a bunch of new product.
considering the fact that it likely isnt even their fault, as the wheel was refinished, and likely not well, i think this is above and beyond anything lmfao. send anything you don't want to me =P
