Windshield - Q's
Old Jun 19, 2008 | 02:45 PM
vrflyer's Avatar
Question Windshield - Q's
I've noticed some pronounced "marks/rings" on the inside of the windshield. Going back to when I purchased the car I do remember it had a banner on the inside (dealer banner).
Basically my question is as follows, what will make these "marks/rings" go away, what do you gurus recommend and what to stay away from?
TIA!
Old Jun 27, 2008 | 07:47 PM
KM1013's Avatar
8th Gear
You can try a singe edged razor blade. Run it along the outside of the window low and out of the way a couple of times to make sure there are no burrs on the edge. Then use it inside on your problem. Then move to #0000 extra fine steel wool. Whatever goo/residue you had should be gone. You can use your favorite glass cleaner to act as a lubricant. I use invisible glass. Also watch out if these are tinted windows (factory or otherwise).
Good luck.
TheMuffinMan
Jun 2, 2022 07:11 AM
bluetl04
Aug 16, 2016 02:49 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
rhdune16
Sep 28, 2015 11:31 AM
rockyboy
Sep 17, 2015 02:37 PM
