Wet sanding Adhesive
Does anyone have any tips. I debadge my car and took it to a detail shop but they couldn't get all of the adhesive off. Does anyone have anytips on wetsanding it off before I funk something up!
Have you tried Goo Gone or WD40? Check out the following thread before you do anything . . . https://acurazine.com/forums/wash-wax-23/shaved-my-emblems-365470/
Needs more Lemon Pledge
Hairdryer, then goo gone?
The guy at the shop used a heat gun and some strong clear chemical with a whole bunch of different danger labels so I'm positive it was stronger than goo gone.
Aceotone? Sufuric Acid? 60 grit sandpaper on your PC? Any of these should remove it, but then you might not like the results afterwards!!
I would have to say that WD-40 would be your best bet.... let it sit on there for a few, hit it again and use some elbow grease.... Repeat as needed.....
I would have to say that wet sanding should be the LAST alternative to try.
Oakes
Wash & Wax
10-12-2015 11:17 AM
