Waxing Questions
Waxing Questions
Okay guys, I just got my car detailed from shop. They shined it up for me and a week later it has rained and now time to wash. My question is, do I have to wax again with some kind of spray wax or could I just use a quick shine like Mothers Showtime? I wanna get the shine back. what's the best way to get shine back.
I need 2 more gears
If you don't know what wax they used call and ask. If it's low grade cleaner wax then use dawn and just strip it off, get a clay bar and make sure your paint is really clean. Then used Meguiars NXT generation Tech Wax, then after you wash car and you see any swirls coming back just use the Meguiars NXT generation booster spray wax. You can use it when car is wet or dry and it is the easiest wax I have ever used. It brings the just waxed shine back that looks sick!
Originally Posted by CLpower
it's probably to dirty for a QD. I'd just wash it, the wax should still be on there.
What wax did they put on it?
Bad question(s) - If I use dawn to strip off the existing wax (I am assuming just use it with water and sponge-nothing special), do I then need to us a polish before the Meguiars NXT? Also, if I strip off the wax, do I have to clay it, or can I just put NXT back on immediately and then touch it up? How about longevity? Also, what about meguiars cleaner? Is that the same as using dawn? Sorry for all the question, but just trying to decide the best approach!!!
I'm Baaack!
Not bad questions ...
I'm not a big fan of Dawn, but if you want to strip the existing wax that's one way to do it. Just remember that Dawn will also begin to dry out things like rubber over time so I wouldn't do it more than once a year. If you do decide to use it, then just substitute Dawn for your regular car soap.
Polishing helps to set up the paint, if you have the time I would recommend it before you glaze or wax.
If you're going to clay it should be done before polishing for a couple of reasons, 1) it removes contaminants from the paint before polishing then drags them around on your surface. 2) If you do any damage with the clay (I put some microscratches in my paint when I clayed) the polishing will smooth them out as well. Many people do not/have never clayed. That's okay too, but your finish won't be as pristine.
After you've stripped the old wax, clayed and or polished, realize that your paint is now virtually unprotected and a good coat of glaze/polish is a must. I used NXT last season with pretty good results. It is extremely easy to use and was pretty durable.
Once you have a good coat of glaze, use a quick Detailer after you wash to maintain the finish.
Also, I do not plan to clay the car, so if I use dawn then a polish, then NXT I should be in good shape?
Do I need to use a polish, or can I just use dawn and NXT and that will cover everything?
Finally, can I just clean the car as normal, put on NXT and have great results?
I used Meguiars clearner Wax about 6 months only and it did an O.K. job, but did not last very long. I am starting to get swirl marks in the finish. Hopefully one (or all) of the above senarios with solve the problem and give me a great shine!!!!
I'm Baaack!
Thanks for your input. So, my understanding is that I do not need to use a cleaner if I use dawn-right? If you're looking to remove the existing wax then you can use Dawn instead of a car wash
Also, I do not plan to clay the car, so if I use dawn then a polish, then NXT I should be in good shape? Sounds like
Do I need to use a polish, or can I just use dawn and NXT and that will cover everything? You mentioned swirls .. I would polish .. search in this forum for polish/swirl removers, I personally use Menzerna with a Porter Cable and have had great results but others use different products.
Finally, can I just clean the car as normal, put on NXT and have great results? See above, if you have swirls, they will probably remain visible under the NXT. I would try and address them before applying NXT.
Last time!!! So do I need to remove the existing wax to get the swirls out, or can I just use a polish and then NXT?
I'm Baaack!
Crazy - your right, but polishing will take off the wax ... (hell if Dawn will do it .. damn skippy the abrasives in a good polish will)
off topic - How'd your first time with the PC go???
Team Anthracite Member
Hey Brewmaster - I use Meguiars NXT, real happy with it. Will a polish prior to NXT give it anymore kick or deepness? Or is polishing before NXT a waste (thought I read somewhere that NXT has something in it that strips away previous laid stuff) Any polish recommendations if you agree I should use one? Thanks.
TB
TB
https://acurazine.com/forums/car-talk-5/detailed-audi-today-so-more-pics-305002/
I'm Baaack!
Tbone - I'm certainly no expert, but a good surface prep (i.e. polishing) can only improve the results you get with any glaze or wax ... somewhere around here I have a pic or two from when I finished mine ...
Here it is: Link
Here it is: Link
Nice!
Hoping I can get mine washed before the rains startup again then spend the weekend detailing - polish, couple coats of NXT. I am going to try and wait in between coats and wait before finishing with a QD. Supposedly the NXT does better when sits for 12 hrs. in between..... We'll see if time allows.
Just installed some flourescent lights from the Home Depot over each bay in the garage - so I can wax day or night.
Here it is: Link
Here it is: Link
I'm Baaack!
NXT is a polymer and my experience was that it lasted pretty long, especially if you QD every couple of weeks.
You'll hear different stories about layering NXT. I did and thought it helped, others have told me that NXT has just enough abrasive in it that it pretty much removes the old coat when you add the new, so layering wouldn't be effective.
Again I thought it looked better after 2 coats, but it may have just been my mentally justifying the time spent.
Former Sponsor
Meg's NXT Wax
You can find a good article about NXT cure time and layering on this site.
IMO the 2 coats would be more insurance that the car has an even overall coating of the product as opposed to actual layering.
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
SinCityTLX
55
10-11-2015 01:20 AM
