Waxing lense covers?
Old Feb 9, 2005 | 09:35 AM
ThePianoMan's Avatar
Vroooooom....Vrooooooom!!
Does anyone here wax, or recommend waxing your tail/head light covers? You wouldn't think that it would hurt.
Comments? Thanks!
Old Feb 9, 2005 | 11:00 AM
burn-one's Avatar
I don't think it would hurt, but Meguiars makes 2 nice products for plastic lenses. I think it is called plastic cleaner and plastic polish. Give those a shot!
Old Feb 9, 2005 | 11:41 AM
UnsanePyro's Avatar
Registered Driver
I don't know about waxing plastic (?) tail/head light covers, but for all my exterior glass I use Klasse AIO. It's marketed for the paint, but makes an awesome rain repelant on the windows. Up above ~40mph everything just glides right off
Old Feb 10, 2005 | 12:13 PM
18anatak's Avatar
I wax em. Doesnt hurt. Why do I do it? I dunno.
Old Feb 10, 2005 | 06:34 PM
big mike 13's Avatar
does anyone know if PlastX is very abrasive?? when i turn my headlights on i see like lines/ or whaver it is all over my housing, im guessing from scratching and rocks.. etc...
will it make it look brand new and smooth if i use it?
Old Feb 16, 2005 | 12:49 AM
dondos2's Avatar
I used to degrease my headlights, rinse then i put basic turtle wax on my altimas headlights and it cleaned it pretty nicely.
ps i used a buffer and youre not supposed to leave the wax on too long
Old Feb 16, 2005 | 12:34 PM
TOGWT's Avatar
The Old Grey Whistle Test
Yes
How- Application Methodology:
·Use a plastic polish to remove scratches or oxidation (avoid solvents as they could compromise the lens coating
·Meguiar’s PlastX contains a microscopic diminishing abrasive, which requires a little pressure when applying it to enable these abrasives to remove the discoloured plastic and expose new plastic. Or Renovo Plastic Cleaner
·Plastic Cleaners can be used to clean and condition Perspex as well as flexible plastic but is not suitable for use on glass.
·Prior to application of a plastic polish ensure that the surface is clean and free from dust particles by washing with a soft cloth and warm water.
·It is not advisable to use cleaning detergents on plastic.
·Shake the bottle thoroughly. Plastic polish can be hand or machine applied
·Using a random orbital buffer with a 3.5-inch backing plate and a 4-inch (LC White) polishing pad or a terry cloth applicator
·Place a small dab (about ½-inch diameter) of plastic polish on the foam pad or applicator.
·Place the pad on the lens surface and turn on the machine (speed #4)
·Polish the lens repeatedly in a left-to-right and an up and down pattern.
·Continue polishing until all the polish is gone
·Wipe the lens with a damp Microfiber towel
·Inspect the lens, repeat the polishing process 2-3 times as necessary
Plastic polish will not remove clarity defects that are within the plastic but it will remove external/surface scratching and oxidation (yellowing)
JonM
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
BIGxRED
Oct 19, 2015 10:47 PM
SinCityTLX
55
Oct 11, 2015 01:20 AM
hashbrown
Sep 29, 2015 12:13 PM
