wax problem
Old Dec 16, 2005 | 04:07 PM
Stealth CL's Avatar
proffesion...axle breaker
wax problem
i just applied a coat of meg's scratch x, and then a coat of nxt. and for the past couple of waxes after my final wipe, ive been getting like swirl marks where the wax just was like it doesnt come off.
i use the turtle wax buffer with terry cloth pads. no matter how much i try to remove the marks they just smear and get worse....i have a blk 01 cl-s
its hard to tell in the pic but, that line you see...thats what happens when i just wipe across it with a cloth, after i buffed it.. any suggestions?
Old Dec 16, 2005 | 06:52 PM
Stealth CL's Avatar
my first thought was humidity, and water vapor was falling on the car and causing the smearing, but today was dry and cooler. so......im out of suggestions. anybody?
Old Dec 16, 2005 | 07:11 PM
Hawhyen51's Avatar
It's been recommended to let the NXT sit for about 15 minutes allowing the product to bond with the surface. Then I'll hand wipe the haze with a MF towel lightly sprayed with a QD. This will eliminate residual dusting and streaking. If you find the product hard to remove or starts streaking, you're probably using too much product. You shouldn't need to use force during product removal. I would recommend getting some MF towels for this purpose.
Old Dec 16, 2005 | 08:49 PM
Stealth CL's Avatar
i use the buffer with a terry cloth pad,i apply product to entire car, so it sits for about 10-15min. and put the buffmaster on the car and let it do its thing. i dont press with force, for the fact that im scared to press to hard and leave swirls.
so are you saying to buff off the product with the terry, and then final wipe with MF,or remove product with the MF?
and do you spray the QD on the MF, or on the car and then polish her up?
thanks for the help, im sort of a when it comes to detailing
Old Dec 17, 2005 | 12:24 AM
SweetJazz's Avatar
2016 E350 Sport
Let's see.......
It sounds like you may not have removed all of the ScratchX. How are you applying the product and removing it? ScratchX needs to be worked in using a 100% USA cotton towel. Remember the product has tiny abrasives that need to be worked in to eliminate the high and low edges of the scratches/swirls. Also, only a small area should be worked at a time (no more than a 12"x12" area). It should take you several hours to complete your car for this step. Buffing off with a good microfiber towel is also a good idea.
NXT paste/liquid wax should not be caked on the car. A thin layer is the best method. Two to Three layers at most. Any more and you are only wasting product. All you will get is more work to remove it. How long are you waiting to put on the next coat of NXT? I usually wait at least 8-12 hours before applying the next coat. Longer if the temperature is cold. I would not use a QD to help remove the NXT. NXT is extremely easy to remove, with a microfiber towel, if your paint is properly cleaned and polished.
What type of buffer is a turtle wax buffer? Is it a random orbital or rotary type of machine? What speed were you using? If it is a rotary type of machine then that could be the cause of your scratches. Also, if the terry cloth pad clogs up with product then that could cause scratches. The best tool for removing NXT is your HAND with a microfiber towel or a dual action polisher such as the Porter Cable 7424 with a microfiber bonnet covering a course polishing pad(stiff foam).
Whew!........
Old Dec 19, 2005 | 11:49 AM
Stealth CL's Avatar
i do the scratch-X a section at a time. and apply with a foam applicator with the cloth cotton, you can buy at anywhere. but i dont wait very long to then apply the NXT i usually apply it within 10-15min of finishing the whole car.
i didnt say that i am scratching the car and putting swils in it , i am trying to remove them from the previous owner, and i applied scratchX once and then NXT, and it did a pretty decent joc but didnt remove the comletely so i thought id give it anothert shot. and this result comes out every time i wax it.
heres my buffer it has only on speed, i think it or orbittal? it doesnty go in a complete circle. i use Vikings terry cloth pad to remove everything, bought at autozone.
SidhuSaaB
May 30, 2020 12:40 AM
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
12vancover
Oct 16, 2015 12:04 PM
SinCityTLX
55
Oct 11, 2015 01:20 AM
