Water spots on the wheels (on the lip)
Old Mar 15, 2009 | 06:34 PM
  #41
Jesstzn's Avatar
Originally Posted by tihomirbg
Oh no. That came out wrong. I wash the wheels first and then I use WD-40.
You scared me for a sec there.
Anyway, after WD-40 has been applied and then buffed of, you are saying to use NuFinsh liquid? Does that give a shine and protection?
Can the WD-40 its a Water Displacement agent containing some solvents. Stoddard Solvent 8052-41-3 45-50% and Petroleum Base Oil 30 to 35%
Nevr Dull = Mineral Spirits – Petroleum Hydrocarbon
This product is C.A.R.B. , V.O.C. Compliant
No I'll just repost form above
First wash the wheel .. then use NevrDull ( im not convinced its WD-40 ) this will clean up some of the oxidization on them. If you need to follow it with a billit polish. Once done put a few layers of a good sealant on them and then wash only with a soft mitt and soap & water.
Wheel wax is a waste of time .. it only lasts just a few washes .. If you don't already have a sealant like Zaino, Duragloss #105, Meguars #21 or something along these lines go get a bottle of NuFinish Liquid.
Carnuba waxes can't stand up to the heat from the brakes and the chemicals given of in the form of brake dust which does become acidic when exposed to moisture.
Old Mar 15, 2009 | 08:22 PM
  #42
tihomirbg's Avatar
Btw,
I just used PB's Polish w/c and I got a lot of black residue on my applicator. On the other hand, the lip turned out shinier and it looks better than when I first started this thread.
Old Mar 15, 2009 | 08:26 PM
  #43
tihomirbg's Avatar
So I might stop using WD-40 and start using NevrDull. Would this product be in my local auto store or it is only online type of product.
Old Mar 15, 2009 | 08:29 PM
  #44
Jesstzn's Avatar
I'll b honest and up front .. I wouldn't use WD-40 on my wheels more than once .. I think it was suggested as a 1 time try for the spots.
NevrDull by Eagle 1 is available at WalMart etc ..
Old Mar 15, 2009 | 09:05 PM
  #45
Jesstzn's Avatar
Btw,
This just confirms they are not clear coated. Try and get them cleaned up as you can then clean off any residue and put a few coats of a sealant on them like Klasse or Duragloss#105. Or any other good sealant.
Old Mar 22, 2009 | 07:22 PM
  #46
tihomirbg's Avatar
As you said any other good sealant, I still have some left over UPP. Is this good? By good, I mean, is it ok to use on the wheels after they have been cleaned and polished?
Old Mar 22, 2009 | 09:36 PM
  #47
Jesstzn's Avatar
That should be perfectly ok
Old Mar 24, 2009 | 06:44 PM
  #48
722ish's Avatar
71Q
I like WENOL red and blue for my CCW uncoated wheels. I dont use a towel for anything, except removal. I use a nitrile glove, apply the polish to the glove, and just use a finger in the glove to polish. I remove with a nice and soft MF towel.
I go WENOL red, then blue. Im normally pretty happy after that. Mothers billet is good off the shelf stuff ive somewhat liked. Just make sure that you dont leave any of them outside. I live here in FL, and a lot of them will separate in heat and humidity of our garage. They all make it inside to hide for the summer. I dont need to replace them all the time. I keep all my stuff inside, but the bugs here are crazy haha!
The glove method has worked the best for me!
Why would the WD-40 not be advisable? I dont see how it hurts? Aluminum oxide is one of the toughest things to break down for sure. I myself have never tried it, however I cant see any major long term ill effect from using the wd-40 to break down the spots.
Id be aware of the rotors and brake parts, but other than that... please let me know if there is something that im missing from the problem here?
good luck! polishing wheels can be a PITA! It is rewarding when they look nice. Ive heard P21s or something polishing soap makes the job easier as well!
take care
Mark
Old Mar 24, 2009 | 06:49 PM
  #49
Jesstzn's Avatar
It wasn't bad for it but he wasn't using it as a one time correction but a daily / weekly application and was seeing hazing and loss of shine.
Old Mar 24, 2009 | 06:52 PM
  #50
722ish's Avatar
71Q
Oh i see, i misinterpreted that!
Thanks for the correction.
Can you reccomend any polishes whatsoever as well? Moreso finishing, as I have a lot of polished aluminum on my car, and it can be overwhelming!
Old Mar 29, 2009 | 05:55 PM
  #51
tihomirbg's Avatar
take care
Mark
By saying glove, what glove are you referring to?
Old Mar 29, 2009 | 07:35 PM
  #52
exceldetail's Avatar
Former Sponsor
Some WD40 automobile uses:
Lines in italics, I have used.
  • Removes tree sap.
  • Removes insects from front grill.
  • Small mammals, not so much.
    When you go on a road trip, bugs can’t help but come along for the ride. Once you reach your destination, reward your car by cleaning off the pesky creatures with WD-40.
    Shines and protects chrome.
  • WD-40 is a miracle worker on cars and trucks, and can help make caring for your vehicle a breeze. Use it to keep your chrome polished and protected.
    Lubricates gas cap locks and levers.
  • Buff out scuff marks on bumpers
  • Removes road debris from license plate
  • Cleans gummy buildup from steering wheels
  • Helps remove protective coverings from new cars
  • Removes melted gum from dashboards
  • Removes gum from floor mats
  • Removes crayon from dashboard
  • Removes melted rubber from exhaust pipes
  • Removes debris stuck on floor mats
  • Helps protect rubber trunk molding
  • Helps remove window tint
  • Dissolves grease
  • Removes excess wax from rubber bumpers
  • Removes paint rub from another vehicle
  • Helps clean metal surfaces
  • Removes paint from leather
  • Cleans and protects aluminum rims
Stupid sappy trees.
Trees provide shade, but they can also provide unwanted deposits of sticky residue on your car, which can harden and even cause damage. Use WD-40 to help remove the residue and keep your car looking great.
Old Apr 1, 2009 | 09:02 PM
  #53
tihomirbg's Avatar
  • Removes tree sap.
  • Dissolves grease
Stupid sappy trees.
WOW, this is some great info. Thanks BTW, when you use WD-40 do you use it with MF?
Will even print this to have it handy.
Old Apr 21, 2009 | 12:05 AM
  #54
tihomirbg's Avatar
I have been thinking about using Z-8 on the wheel lip. Would that be OK. Using Z-8 after 2 coats of UPP. Any benefit of this?
Old Apr 22, 2009 | 03:50 PM
  #55
MD03CL-S's Avatar
Were you able to get a combo of products that did the job? I have been having a slightly similar issue with my wheels and have not got it....yet
Old Apr 22, 2009 | 04:39 PM
  #56
tihomirbg's Avatar
Yes, I got around this. Go and buy NevrDull by Eagle 1. Use small amounts of it all over the lip. Leave it for few seconds go get clean towel and buff until you see the mirror shine. Your towel will get dirty quickly. Try to use clean towel as you buff it. That will guarantee you cleanliness. Then, I use UPP for protection. I even applied 3 coats with 24 hours between each coat.
rockyboy
Aug 4, 2024 10:35 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
acurajj
Sep 19, 2015 03:47 PM
GhostTL09
Sep 19, 2015 01:57 PM
PortlandRL
Sep 14, 2015 12:01 PM
