Tree Sap
Old May 23, 2007 | 12:40 PM
hardrock32tls's Avatar
Tree Sap
I have a situation that I would like to get some input on, specifically from the Pros, and in particular Exceldetail (Patrick). Because of where I have to park my car, this time of the year I get sap dripped on it from the Ponderosa Pine that sits next to the driveway. I relgiously try to keep the car as clean as possible, and at least a couple times a year I polish and seal it with 4* UPP. The sap droppings that usually end up on the car are anywhere from the size of a pea to the size of quarter. In order to remove the sap, hopefully before it hardens, I dampen a wiping towel with a small amount of Denatured Alcohol and carefully wipe up the droplet. The denatured alcohol cuts the sap fantastically, and the amount of wiping to remove the sap is minimal. What I do then is hand apply some Poorboys Cleaner polish to the area, to clean up any residues left behind and then reapply the 4* UPP.
My main question is this, what effect does denatured alcohol have on the 4*? Does it remove the sealant as easily as the sap? I don't take any chances and I do re-apply the sealant after a sap strike. Am I going overboard or should I be doing something more?
Old May 23, 2007 | 02:57 PM
exceldetail's Avatar
Former Sponsor
Denatured alcohol will remove a protion for sure, as for removing it completely, its real hard to say. Common sense should prevail here though. And whatever the Denatured Alcohol doesnt remove, the PB Polish will. At a minimum, use a Spray wax i.e. Duragloss AW, or FS UPPS (Best) for a quick recovery.
Then better case scenario, hack that friggin tree down!
Old May 23, 2007 | 03:13 PM
Well that has been considered quite strongly.... and it may happen soon but until then I just want to make sure that when I have to remove the sap that I am still protecting the finish on the car. I think that what I am doing is the best way to do it for now.
Old May 23, 2007 | 04:44 PM
Deus's Avatar
Have the same problem. I got a car cover right away and no more problems.
Old May 23, 2007 | 04:47 PM
Former Sponsor
But now you have it all over the cover! Tree sap sux!
Old May 24, 2007 | 08:56 AM
Deus's Avatar
I feel ya pain brotha. I much rather have that shi* on the cover than my car tho
Old May 15, 2008 | 12:00 AM
TLAdvanced's Avatar
The Kinetics of Bleu
UUUUUUGGGGHHH!! I work at a drug / alcohol rehab in the forest. I love my job, but it's a real hassle with the car. First off I need to go down the 1/2 mile dirt road entrance. Then, I need to be real careful where I park because there are a crapload of ferrel cats and they like to lay on the cars. The few spots I found that the cats don't go is apparently too close to a pine tree. Now I have millions of tiny sap spots covering the entire car. What is the BEST method of removal? Is it the denatured alcohol?? Also I guess whatever I use will also take off the wax so I will need to re-polish and wax, right??
Old May 15, 2008 | 07:50 AM
vinnier6's Avatar
if i had to drive down a dirt/gravel road or park by a tree where birds and tree sap are killing my car, i would get a different car, one that i didnt car about....it way to hard to have a nice car and park and drive in shity conditions....i guess i am lucky, i go from garage to garage....my car doesnt even sit out in the sun....
Old May 15, 2008 | 08:53 AM
Jesstzn's Avatar
Each type of tree emits a difference type of resin (sap), at different times of the year.
Do you have any idea of what kind of tree sap is on your vehicle?
First, try "soaking" with a solution of a water based all purpose cleaner, properly diluted, on a cool surface, in the SHADE!
Let it soak for at least 5 to 10 minutes, keeping it wet with the solution, don't go playing "rubby dub" or you might created some serious scratching,etc, which then makes more work.
If, after it sets and you have wiped it off and washed off with plain water, they are still there, move to the next step.
Since most "grease/wax/tar" removers contain a fairly high percentage of xylene in them, do not recommend their use except when preparing a vehicle for sanding and repainting..
Honestly, the safest hydrocarbon remover you can use is naptha, used in many of the polishing and waxes used on vehicles, just under a different CAS#. Soak and let set, then wipe with a towel wetted with the naptha.
Where do you get naptha, simple, it is "lighter fluid" and will do nothing more than remove any wax or sealant on the clear.
Another, is plain old "rubbing alcohol", that's right, the stuff under most people's sinks.
It will not harm your finsh, just use it the same way, "LET IT SOAK", DON'T GO GETTING ALL IN A HURRY AND RUBBY DUBBING!
If none of these work, and I doubt at this time of year any pine type trees are emitting turpene this early, go to the clay.
You may get some scratching with clay, so be prepared to do some polishing after using it.
There are your "guide lines", as there are many types of trees, each with their own sap/resin emitted.
Old May 15, 2008 | 10:15 AM
TLAdvanced's Avatar
Thanks a lot! I'll update you on how it works out...
Old May 19, 2008 | 12:19 PM
club_euro2's Avatar
Detail Shop in Maryland
hello,
can someone please recommend a good detail shop in the rockville, md area.
Thanks,
Umair
Old May 20, 2008 | 03:50 AM
TOGWT's Avatar
The Old Grey Whistle Test
Stoner’s Tarminator (Tar, Tree sap, Bug debris, and etc) apply paint protection after use
Old May 20, 2008 | 07:10 AM
Former Sponsor
I cant believe I left WD-40 out of this picture.......
Old Aug 14, 2008 | 11:47 AM
Brandon24pdx's Avatar
Por Favor?
Sap sucks. I took my car camping for a few days and came back completely covered in little clear spreckeles of that crap.
Clay seemed to do an okay job of removing the "sharper" bits of the stuff, but wasn't working so well on the "smoother" specks. I'm gonna try some WD-40 or rubbing alcohol and a microfiber towel to see if I can get the rest off.
Dont take your car camping if you're the kind of guy that hangs out in detailing forums...mine came back totally trashed.
Old Oct 20, 2008 | 11:26 PM
chinesestunna's Avatar
Just got some sap on my car too tiny microscopic bumps, I was able to wipe it off with just McGuire's quick detail (only about 2-3 hours after parking under tree, so sap isn't hard yet) hope this helps
thanks
Old Oct 21, 2008 | 08:40 AM
Jesstzn's Avatar
thanks
What removes the sap depends on the sap ... some is water soluable .. you were lucky .. some isn't and water or a QD won't do it ..
Old Oct 22, 2008 | 08:53 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
Hot soapy water has worked the best for me.
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
Rob144
Sep 21, 2015 08:18 AM
Caddy
1G RDX (2007-2012)
Sep 18, 2015 12:44 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
