Touch-up paint
Old Jul 22, 2007 | 12:43 PM
calvin_hobbes's Avatar
Touch-up paint
Folks,
I have noticed several chip-offs (around 15-20) on my '05 RL. How would i go about touching it up? (a search on the forum revealed plenty of results, hence, a pointer to the actual thread, if already covered, would be appreciated).
Is it recommended to purchase the paint (lakeshore silver metallic) from Acura dealer or a nearby Pepboys/AdvancedAutoParts etc? What other accesories would i need to do the job myself? How long do touch-ups last generally speaking? Is it worth to get them done professionally? If so, how much should i expect to shell out?
Your help is always appreciated :-)
Old Jul 22, 2007 | 12:55 PM
siriustsx's Avatar
https://acurazine.com/forums/showthr...ht=touch+paint
I found that on here the other day, and it's the best write up I've ever seen... Should answer any question you could ever have.
Old Jul 22, 2007 | 09:32 PM
stokdgs's Avatar
Here is a URL for a really good paint chip paint -
http://www.drcolorchip.com/
I have used it on our '04 MDX and it is great. Its not the cheapest, but you get what you pay for. It comes in a really nice wooden box, there are a few different sized brushes and pads, theirs is a 2 step process, a bottle of paint and another bottle that you wipe over your painted chip to help blend it and make it turn out - in my case really good.
You already know it looks like, that paint chip repair doesnt last forever because its not the same paint, its new paint, and it doesnt bond as well as the original baked on finish, but this is I think about as good as it can get. Perhaps you can try it and if you cant live with it , sometime have the hood/front end repainted, and then put a clear bra on it ? Just dont do this right away because repaints need a little time to dry, since they are probably not baked on like your original paint was.. Good luck DanF
Old Jul 29, 2007 | 11:26 AM
psteng19's Avatar
Tagged
Old Aug 11, 2007 | 02:18 PM
Vicman17's Avatar
Originally Posted by calvin_hobbes
Folks,
Make sure to clean the chipped area with alcohol/ water so the paint bonds properly.
Dupli-Color from Wally mart (less than $12.00) is better than the Acura paint. Metallic is really very difficult to match and as long as it is the right color code, you should be OK. Dupli-Color also sands down better and doesn't come off with the rag. I use an old credit card wrapped tight in an old white cotton shirt cloth. Then I use Meg's #9 Swirl Remover (Pretty much like the Lanka kit) and rub it with the smooth/ flat end of the card facing down on the blob. (If you have a good amount of compound, you won't scratch it). Usually you can rub down the blob after 5 hours or so and even sooner if the car sits out in the sun.
You gotta realize that this is time consuming work as you have to even out each and every one of the chips (start with the big/dep ones first).
After you even out the paint, apply sealant (Klasse) on the spot and your favorite wax. With regular cleaning , sealing, waxing the touch up should last a long time.
If the stone chips are quite extensive, a good body shop could probably do it for around $500.
Old Aug 11, 2007 | 08:13 PM
paradigm's Avatar
http://www.paintscratch.com/
the above vendor has had good reviews on other sites such as autopia
.02
Old Aug 11, 2007 | 10:21 PM
Jesstzn's Avatar
I have Paintscratch ... works great ..
Old Aug 12, 2007 | 08:53 PM
Originally Posted by psteng19
Tagged
pardon the ignorance, but what does being tagged imply?
Old Aug 12, 2007 | 08:56 PM
thank you for the reference siriustsx... i should have responded earlier, but you know how it goes
Old Aug 12, 2007 | 08:58 PM
thanks for the link stokdgs..
my chips have occured on front portion not covered by clearbra (closer to the wiper assembly) unfortunately the clearbra guys refused to do a coat beyond a certain point... i wonder why
Old Aug 12, 2007 | 09:01 PM
The more i read about this, the more i think i am at risk of seriously screwing up the good paint around the chips as well... at a nearby carwash place, i found a guy who, for about $120, touches-up all chip-offs on the car (around 2-4hr job).. i am thinking of using him to see how it turns out..
Jul 16, 2017 07:33 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
jmaxima03
Sep 27, 2015 10:22 AM
spoiler900
Sep 23, 2015 04:41 PM
