Steps?
Old Dec 12, 2013 | 12:18 AM
Sarlacc's Avatar
The Third Ball
Steps?
If I'm going to clay my car...is there any reason to polish it prior to waxing?
Thanks.
Old Dec 12, 2013 | 12:44 AM
Aman's Avatar
Your Friendly Canadian
Just to get rid of swirls and such... otherwise, no problem waxing after claying.
Old Dec 12, 2013 | 06:44 AM
if you dont have the time or means, you can defintely skip the polishing step.
as aman stated the polishing step is actually correcting the paint.
Old Dec 12, 2013 | 08:18 AM
Sarlacc's Avatar
The Third Ball
Old Dec 12, 2013 | 08:36 AM
C8N's Avatar
C8N
Clay has the potential to leaving some marring in which case you would want to polish.
However, as long as you use fine grade clay, you should be ok.
Old Dec 12, 2013 | 08:45 AM
Jesstzn's Avatar
Between claying and waxing wipe the car down with a 50/50 mix of rubbing alcohol & water to give the wax/sealant a good surface to be applied to.
Old Dec 12, 2013 | 06:37 PM
dnd2984's Avatar
What he said.
Use a fine poly clay and you should not need to polish, just use a lot of clay lube or, I stick to ONR and distilled water.
Old Dec 12, 2013 | 06:38 PM
dnd2984's Avatar
have you tried adding some Megs D114 to your IPA solution, excellent result and little to no marring
Old Dec 12, 2013 | 07:30 PM
Sarlacc's Avatar
The Third Ball
Meh. I just did wash, clay, polish, sealant
Ran out if time...and my back is shot after that. Still have to do the wheels, glass, and interior.
Sigh
Old Dec 12, 2013 | 07:32 PM
Sarlacc's Avatar
The Third Ball
Biggest bitch was taping off my stripes and then wiping down the shit that got stuck along the edges.
Old Dec 13, 2013 | 09:50 AM
C8N's Avatar
C8N
Sigh
Nanoskin Autoscrub and a DA.... your back will thank you for it.
Old Dec 13, 2013 | 09:54 AM
Sarlacc's Avatar
The Third Ball
Interesting, thanks.
Using the orbital for a polish and sealant...thats what did me in.
I need a lift, so I can raise the car to do the side panels
Old Dec 13, 2013 | 10:23 AM
Jesstzn's Avatar
Does it also remove the little rust blooms that accompany the rail dust .. Clay removes the rail dust easy but the brown stain is another story.
Old Dec 13, 2013 | 12:29 PM
stogie1020's Avatar
Needs more Lemon Pledge
I got a little shop stool on wheels for JUST that reason.
similar to this but cheaper...
http://www.lowes.com/pd_2627-20535-8...ductId=3338522
Old Dec 13, 2013 | 01:48 PM
C8N's Avatar
C8N
I actually don't know the answer to that question....
But supposedly, it is supposed to do everything a clay does
I guess one could should use IronX if the Nanoskin doesn't.
It's just that Nanoskin is so much easier to use than clay.
Old Dec 13, 2013 | 02:03 PM
Sarlacc's Avatar
The Third Ball
I was sitting on a bucket...didnt help.
Old Dec 13, 2013 | 02:29 PM
Jesstzn's Avatar
Ok thank you .. No one seems to have that answer .. Not interested in IronX etc ..
Old Dec 16, 2013 | 04:12 PM
C8N's Avatar
C8N
I asked the question in Autogeek and the response I have received was that both clay and nanoskin will remove iron contaminants.
http://www.autogeekonline.net/forum/...-iron-x-2.html
Refer to post #20
Old Dec 16, 2013 | 04:29 PM
Jesstzn's Avatar
Refer to post #20
Ya same answer I got but iron contaminants and the brown stain are 2 different things . I can clay off the iron filing in 3 seconds so the surface is butter smooth but that brown iron oxide stain usually takes some polishing. I asked this same question to Detailers Domain in an e-mail .. didn't get a response.
tsx_boy
Dec 13, 2019 08:33 PM
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
DerrickW
Nov 15, 2015 05:52 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
