Some one puked.
Some one puked.
Last night my friends sister booted in my car.
She was sitting shotgun and she hit the side of the door, the seatbelt, and down between the seat and the door. So the worst spot ever to clean.
I got all the chunks and shit out but the car STINKS OF ASS!
what is a good deoderizer that will get the naztyness out?
It would behoove you to get it out of the carpet as soon as possible, thats a given! And I hope you have access to at least a shop vac. You really need to get some all purpose cleaner, and dilute it according to instruction for carpet cleaning, probably around 25, 30:1. Spray the area liberally, but not down to padding. Agitate with a stiff nylon brush, and vacuum it up. After you have completed this on all affected areas, take a microfiber or cotton towel, rinse it in water, and go over the area again. Repeat this procedure on all areas. Try to leave the windows cracked in the evening until your sure it has dried completely. If you have a do it cenetr type store close to you, invest in one of those closet deoderizers, made from volcanic rock, and leave in the car, under the seat.
Next time, leave your pals sis at home !
Thanks for the advise
~One man’s opinion / observations~
Upchuck -remove residue from mats and/or upholstery with a stiff nylon upholstery brush. Use a carpet extractor on any fabric or upholstery effected, hand rinse with a disinfectant (Lysol) / diluted APC / water solution to kill any bacteria (you may need to do this 2-3 times). Hang carpet mats to dry/air and open all windows (if possible to allow interior to air out) Place an Elite® odour-neutralizing, porous volcanic lava rock, that's non-toxic and environmentally safe in the vehicle. Spray Ozium 1500c air sanitizer/freshener to effectively eliminates bad odours, each mist will release a pleasant fragrance that kills odour-causing bacteria and converts them into clean, fresh air
~Hope this helps~
Knowledge unshared is experience wasted [each one / teach one]
justadumbarchitect / so I question everything/ JonM
~Hope this helps~
~Hope this helps~
~Hope this helps~
Where can I buy that lava rock?
Originally Posted by gochan
get it detailed and give pukey the bill.
Well, maybe not about the bill part, but a professional detailer should have the right tools to get into the carpet and get them really clean, better than the average person can with the tools one generally has available.
Ashburner
Home Theater & Electronics
29
08-08-2008 03:51 PM
