silicon removal
Old Feb 8, 2011 | 06:04 PM
Toddy's Avatar
Registered Member
silicon removal
Any tips on Removing silicon from headlights that were resealed?
Old Feb 9, 2011 | 01:11 AM
civicdrivr's Avatar
Razorblade?
Where is the silicon? Along the seam between the two parts?
Old Feb 9, 2011 | 01:24 AM
stogie1020's Avatar
Needs more Lemon Pledge
http://answers.google.com/answers/th.../id/33181.html
Old Feb 9, 2011 | 01:56 AM
Toddy's Avatar
Registered Member
Ya working on fixing some things the genius that owned the car before me did. He used black RTV and got it everywhere
Old Feb 9, 2011 | 02:16 AM
stogie1020's Avatar
I have a buffer. If "it will buff right out", I mean.
Old Feb 9, 2011 | 02:25 AM
DaChef320's Avatar
Registered Member
Silicone headlights?how the surgery went ? you should also get clear bra ?
Old Feb 9, 2011 | 02:40 AM
Toddy's Avatar
Registered Member
Nah I prefer to be topless
Old Feb 11, 2011 | 10:04 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
Are you talking about the silicon packets in the housing or an exterior silicon sealant bead?
Old Feb 11, 2011 | 10:36 PM
Toddy's Avatar
Registered Member
Silicon sealant bead that was used to seal the headlights after they were blacked out, it spewed out and the owner just smeared it everywhere to fill the crack... Kinda annoying. The only stuff I found said not to use it on plastic
Old Feb 12, 2011 | 02:06 PM
stogie1020's Avatar
Can you use either claybar or a some headlight polish (is it glass or plastic?) on a polish pad or a foam applicator? May take some effort but it should polish off.
Have you tried:
http://www.amazon.com/Meguiars-G1231...=pd_sim_auto_2
By hand on the areas with the silicone? You may need to use a scouring pad to remove the silicone from the headlamp first and then polish the entire headlamp to get it consistently clear.
Old Feb 13, 2011 | 10:14 AM
powerflow's Avatar
Wiggy Wiggy Wiggy
That sucks, I would try picking / peeling / rubbing it off by hand, then try clay bar, polish.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
dainmezron
Oct 16, 2015 06:56 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
