Scratch Question
Old Sep 2, 2007 | 08:19 PM
dug-mac's Avatar
Question Scratch Question
I probably should know the answer to this, but I don't so here goes. I have a small scratch about 3/4" on the hood of my TL. I just washed and waxed today. My question is should I use something to remove the wax in that area before I use touch up paint? Suspect I should but I don't really know. Sorry if this is a dumb question...
Old Sep 2, 2007 | 08:37 PM
BIGTUFFGUY's Avatar
2003 TL-S A-SPEC
No such thing as a dumb question.
When I touch up minor imperfections I make sure I'm working on a clean and dry panel. I would clean the area with warm diluted dish washing liquid formula. This will remove the wax. Then with a light alcohol solution i would prep the area.
Once thats dry I apply the touch up paint, let it dry as per the directions. Once dry clay bar the area to smoothen it out. Then buff and reapply the wax + sealer.
Hope this helps.
-James
Old Sep 2, 2007 | 08:46 PM
dug-mac's Avatar
Thanks, that explains it...
Old Sep 2, 2007 | 09:22 PM
Hawhyen51's Avatar
You should also check out this thread as an alternative means to scratch repair. . .
Old Sep 2, 2007 | 09:46 PM
dug-mac's Avatar
Thanks, that was a good read...
Old Sep 3, 2007 | 09:17 AM
BIGTUFFGUY's Avatar
2003 TL-S A-SPEC
The answer i gave you reflected your original question. If you want to post a picture of the scratch it may help.
Exceldetail's write up is great. the Products he used are inexpensive and achieve great results.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
Hines57
Sep 24, 2015 01:58 PM
spoiler900
Sep 23, 2015 04:41 PM
