Removing Water Spots
Just washed my car in the sun. I know, I know. Not supposed to, but I didn't have a place to do it out of the sun. Anyways, after washing, I noticed that there are a bunch of water spots. Short of washing the car again, what is the best way to remove them? What products?
TIA
TIA
I think you have to wash it again. Some have recommended a 50/50 solution of water and vinegar to remove the water spots. After that, you'll have to wash the car. And I would recommend another coat of sealer/wax/etc.
i thought I have to use vinegar if the car has hard etched spots. It's a new car and never had water spots before. I am just lazy.
I read somewhere that "detailer" sprays may work for this?
The Old Grey Whistle Test
Hard water contains alkaline minerals that can be removed with an acid (vinegar is a Acetic acid) use a 1:1 distilled water / vinegar solution, wash and then reapply a wax/sealant protection
JonM
JonM
I need 2 more gears
screw using vinegar, thats too abrasive! Never put a moderate acid on your paint. Get some decent polish and those water spots are gone, or just wash it again and they shoudl go away unless they are really bad@!
Anubus 12- you could also try-This glass cleaner (Glass Scrub™) removes insect smear, road oils, mineral deposits, lime scale, tree sap and more. A heavy-duty, cream cleanser that deep cleans auto glass safely and effectively without strong acids, alkalis, phosphates or solvents. It is specifically formulated to clean glass without scratching. The best time to use Glass Scrub is after you've washed the car but before you dry it. The glass must still be wet. I apply a small amount of product on a folded Glass Cleaning Cloth rubbing the glass in circular motions making sure to apply to all areas thoroughly. Flip the cloth to a clean dry surface and rub again. http://properautocare.com
JonM
Originally Posted by PenguinQX
This might sound stupid, but I've never needed more than just a damp cloth to wipe away water spots... I know it sounds really obvious, but make sure you try that first.
Former Sponsor
Fresh water spots arent a problem, due to over-sun-exposure. They will wipe easily away with either a damp MF or a spritz of QD. I would go with QD for the added benefit of slickness and protection. QD's are cheap insurance from bird droppings, sap, and, future water spots. And I would definetly use vinegar, even full strength, over polish.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
STL TL-S
09-23-2015 08:52 PM
