Remove Worst Smell Known to Man
Old Aug 19, 2009 | 09:29 AM
Whiskers's Avatar
Go Giants
Dog puked or maybe crapped in my car, was all over leather seats and floor and a little under the seat. Using a carpet steamer, fabreze and whatever else I could do, I spent a few hours. Removing seat doesnt seem to be an option, but I can't visably see anything left. Car still smells on the floor up close. What can I spray in my car to get rid of the smell?
Old Aug 19, 2009 | 09:34 AM
exceldetail's Avatar
Former Sponsor
Oh man...........
Im not even going to ask how this all happened, although Im quite curious?
Sounds like you need a full decontamination. My worries are the odors and "funk" have absorbed into the carpet fibers and possibly the underlayment. Its probably eaiser to have that replaced, (although expensive) vs. cleaning. I mean what choices do you have here? Everything has to come out and be cleaned thoroughly........Maybe theres a steamer hiding under something, somewhere and you'll get lucky.
Crap (no pun intended) I wish I had an easy answer for you.
Old Aug 19, 2009 | 09:39 AM
FirePR2002's Avatar
bringin lead
teach the dog to do this instead?
Old Aug 19, 2009 | 09:40 AM
Whiskers's Avatar
Go Giants
Would a good detailer know how to remove the seat? I know I can't (electronics, bolts, etc).
Whiskers's Avatar
Go Giants
Old Aug 19, 2009 | 09:48 AM
FirePR2002's Avatar
bringin lead
why not? shouldn't the electronics have clips that unhook? can you see anything under the seat? my bet is that there is crud in the carpet under the seat that has not been cleaned totally.
Old Aug 19, 2009 | 10:05 AM
Whiskers's Avatar
Go Giants
hmm..Thanks.
Old Aug 19, 2009 | 10:12 AM
CocheseUGA's Avatar
All seats can come out. It's just a matter of how hard it is to do.
Old Aug 19, 2009 | 10:19 AM
HEAVY_RL's Avatar
Removing the seats are easy with the right tools.
The bolts will be tight to break loose, and they have to be torqued back down appropriately.
But the "wires" all have disconnects that only connect one way and they are usually unique in size, shape, and/or color.
Easy job, and you have hundreds here to help you if you get stuck.
Old Aug 19, 2009 | 10:21 AM
Whiskers's Avatar
Go Giants
I need tools I guess...
Old Aug 19, 2009 | 11:31 AM
hANDYcaptd's Avatar
It's the Halladay season!
Rear seats should be easy. Front seats, a little bit harder. But nothing impossible. Which seat was it?
Old Aug 19, 2009 | 01:00 PM
achenator's Avatar
If they are the front seats, try to unhook the electronics. Unclip all the wires from underneath the seat. The seat should be bolted on all four corners, the bolts are usually under plastic covers that snap on somehow. Bolts will be tight. It may take a while to figure out the clips on the wires for the electric seats.
The seat bottom for the back seat should pull out though it will be tough.
If this is your G, get on the G35 forums and ask for help over there.
Old Aug 19, 2009 | 01:35 PM
Summer's Avatar
My advice:
Use this stuff: http://www.naturemakesitwork.com/home/index.php
(Nature's Miracle enzyme cleaner)
Pour it on, rub it off. Pour it on, rub it off. Spray it on, and let it air dry as long as it takes (with a fan if necessary).
If still stinky, sprinkle with baking soda. Let it sit, vacuum it up. Spray wit Nature's Miracle, sprinkle with baking soda, let it sit, vacuum it up.
My dog peed like crazy on my unprotected PILLOW TOP mattress, and this (along with hydrogen peroxide, though I believe that can bleach non-white fabrics) took out everything - no stain, no smell, not even visible under blacklight.
Good luck!!!
Edit: between the spraying and air-drying, this process took me about 3 days on my mattress. But, it worked!
Old Aug 19, 2009 | 02:29 PM
Whiskers's Avatar
Go Giants
After a few washes and sprays, its going....Should be ok Thanks all.
Old Aug 22, 2009 | 03:45 PM
4tLA-SPEC's Avatar
sorry to hear... but this happened to me too. i took out my carpet and hand washed it with soap and the garden hose. after it was back to normal.
Old Aug 22, 2009 | 04:42 PM
Whiskers's Avatar
Go Giants
Going to the detailer tomorrow. $120, they said they can get the stink out..
Old Aug 22, 2009 | 09:39 PM
Summer's Avatar
Eh, might be worth the $$ if it's really that stinky! Did you try the Nature's Miracle, though? I bet you could get the smell out by yourself... but again, it depends whether or not it's worth the $120 to avoid cleaning out nooks and crannies filled with noxious biowaste materials :-p
Old Aug 24, 2009 | 04:27 PM
Whiskers's Avatar
Go Giants
$130 seemed to have done the trick...
Old Aug 25, 2009 | 01:49 AM
breitling_1884's Avatar
3rd Gear
That bites. This is why i banned the dogs from our TL regardless of the circumstances. Love 'em but not enough to let that happen. That's why we have the Expedition.
Old Aug 27, 2009 | 05:52 PM
conan777's Avatar
Did they use an "OZONE" machine? that's what I would have recommended for removing odor.
Old Aug 27, 2009 | 06:38 PM
NAiL05's Avatar
That sucks man...But I dunno...Decomp I think is worse lol especially when it dies in your blower motor.
Old Aug 27, 2009 | 06:42 PM
slowaccord's Avatar
this is why pets arent allowed in my house or car.
Old Aug 27, 2009 | 06:55 PM
Whiskers's Avatar
Go Giants
Yes.
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
dainmezron
Oct 16, 2015 06:56 PM
lowgrowl
Sep 26, 2015 05:18 PM
