quick clay question
Old Jul 4, 2006 | 10:50 AM
RJANACONDA's Avatar
Registered TL Lover
Question quick clay question
is there any major differace in the clay products/systems out there? I am thinking about adding claying as part of my detail. So I am woundering on which to get. Do that all do just as good as one another or are there "good" and "bad" ones?
Old Jul 4, 2006 | 10:55 AM
exceldetail's Avatar
Former Sponsor
Most are good as long as they're coming from respected people. Mothers would be my first OTC recommendation. There are some clays that contain a lot of plastics which are not all that plyable (soft) and will mar the paint. But so will a good clay bar, so be prepared for additional polishing. Claying is a very short process which results in ear to ear grinning, easier polishing and all around, beautiful results. For $10.00, its a no brainer..
Old Jul 4, 2006 | 11:17 AM
RJANACONDA's Avatar
Registered TL Lover
ok great out the the ones availble onlie which would you recommend
Old Jul 4, 2006 | 11:26 AM
Hawhyen51's Avatar
RJ, there are different grades (medium, fine and ultra fine) and used properly will remove imbedded contamination from the paint surface. Most detailing clay is repackaged for individual companies and sold as their brand. Available as a kit (lube and claybar) or separately, prices will vary on each site. I'll purchase clay from online sources such as Exceldetail. This is an excerpt from Autopia;
Although most of the clay made today comes out of a single factory in Japan, the formulas can be significantly different, including:
*Clay resin density (firmness)
*Abrasive particle size
*Type of abrasive
*Abrasive density (ratio of abrasive to clay)
*Color
Detailing clay formulation determines the optimal function of the clay and its potential to do damage when used improperly. As an example, professional grade clay that’s designed to remove paint overspray is very firm and contains abrasives equivalent to heavy rubbing compound. Used properly it will remove heavy overspray without damaging the paint. Used improperly, it can leave some pretty significant surface marring. That’s why it’s a professional product.
Old Jul 4, 2006 | 11:28 AM
joerockt's Avatar
Just dial 1911
If you have a car that hasent been clayed in a long time, I like Clay Magic. That bar seems to be a lot duriable then some of the others I've tried...
Old Jul 4, 2006 | 11:30 AM
RJANACONDA's Avatar
Registered TL Lover
thanks guys good info
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
Oakes
Wash & Wax
Nov 12, 2015 09:34 PM
Strath
Sep 27, 2015 11:53 PM
HOWELLiNC
Sep 20, 2015 04:21 PM
datadr
Sep 12, 2015 09:12 PM
