Question about claying windshield.
Old Jan 19, 2005 | 11:20 AM
Kindred97's Avatar
I have the mothers clay kit, is it safe to use the quick detailer spray that came with it as the lubricant on my windshield? Thanks.
Old Jan 19, 2005 | 11:55 AM
car_lost's Avatar
i've used it before... then i washed the windshield with car soap & water and dried it. came out squeaky clean and smooth.
Old Jan 19, 2005 | 11:57 AM
CLpower's Avatar
teh Senior Instigator
also, try and use an old clay bar, cause the one you use on the windshield shouldn't then be used on paint.
I have a huge ball of old clay I save for glass and wheels
and yes, i'd use the QD that came with it.
Old Jan 19, 2005 | 12:03 PM
car_lost's Avatar
ha, good thing that was the last thing i did then
Old Jan 19, 2005 | 12:33 PM
DarkWraith33's Avatar
Team Nighthawk MechE
OK... I'll bite...
Why clay the windshield??? I understand for the paint... Once you've clayed the glass even once (for whatever reason) why would you need to do it again?
Sorry if a NOOB question.... But I'm new to the clay action...
THANKS!
Old Jan 19, 2005 | 12:48 PM
01bluecls's Avatar
"You my boi blue!"
DarkWraith33
OK... I'll bite...
THANKS!
Claying in general shuold be done about twice a year or so if needed. The windshield is just as exposed to fall out, and many other contaminants as the paint is. Claying is a very effective way to clean the windshield and wheels as most wash cloths wont be able to "grab" most of these contaminants. As CLPower said, save fresh clay for the paint and then use old clay for wheels and the windows.
Actually, for the clay lube used on windows i would use a light mix of car wash soap and water. I have even used some mild glass cleaner for lube on the windows when claying. The reason I might not want to use any of the quick detailers for lube is sometimes most of those contains a good amount of oils for paint and will smear and will be hard to get off the windshield. I dont think using the qd for the window is a bad idea, but a waste. Save the quick detailer for the paint and just put car wash soap and water in a spray bottle for the clay lube.
Old Jan 19, 2005 | 12:50 PM
01bluecls's Avatar
"You my boi blue!"
Another note about claying the windshield, ever have stuck on bugs, tree sap or bird poop that seems like they dont want to come off with a wash cloth?? Claybar is VERY effective up cleaning up these stuck on messes.
Old Jan 19, 2005 | 12:56 PM
CLpower's Avatar
Originally Posted by DarkWraith33
OK... I'll bite...
THANKS!
same reason to do the paint
Old Jan 19, 2005 | 02:06 PM
Kindred97's Avatar
Okay thanks everyone. I actually already clayed my windshield using the QD before posting my question. I was just wondering if it was unsafe to use the QD. When I go home I'll give it an extra cleaning with Stoners.
Reason why I clayed the windshield....water spots.
Thanks again.
Old Jan 20, 2005 | 02:34 AM
chewi's Avatar
Thanks again.
So after claying the windshield...will water stick on the windshield? or will it sort of bead off nicely.... I don't want water to stick on my windshield when its raining...
Old Jan 20, 2005 | 07:05 AM
01bluecls's Avatar
"You my boi blue!"
Give the windshield a good cleaning then apply a sealant to it to make the water bead. I clayed my windshield applied Klasse AIO and Zaino Z2. My window is still beading nicely after two months. Or you can use RainX as well.
Old Jan 20, 2005 | 07:13 AM
Jerky's Avatar
Photoshops, and Polls!!!!
my experience with rainx is that it doesn not last very long!!!
Yes, I will clay bar my car and windshield as well...a mix of soap and water makes good sense.(or car wash soap)
Old Jan 20, 2005 | 10:23 PM
18anatak's Avatar
I think claying the windshield is useless. I dont see any benefit at all. I've never done that, if i've ever had any issues on the windows i've used steel wool, and that works fine. IMO, claying a windshield a waste of time.
Old Jan 20, 2005 | 10:45 PM
car_lost's Avatar
i had a ton of small spots on my windshield (almost like it dust that was stcuk on). i tried washing it off, but nothing. i clayed my windshield and it came right off. so it was worth it to me.
Old Jan 20, 2005 | 11:24 PM
18anatak's Avatar
Well, shit, i'm glad everything worked out for you
Old Jan 20, 2005 | 11:59 PM
car_lost's Avatar
thanks!
i think
Old Jan 21, 2005 | 10:15 AM
CLpower's Avatar
yes, but a steel pad does risk the chance of scratching (done it myself)
Claying does do a great job, it's the same theory of doing it to your paint, contanimants stick to the class. Give it a shot yourself before you say it'd be a waste of time.
Old Jan 21, 2005 | 10:16 AM
CLpower's Avatar
but be warned, if you have an old windshield you'll notice all the little chips after claying
Old Jan 21, 2005 | 10:35 AM
18anatak's Avatar
I've done steel wool a TON of times, and never had any problems. just have to be sure that you use enough glass cleaner, and you ll be fine.
Old Jan 23, 2005 | 04:39 PM
123456SPEED's Avatar
CLS 6MT Navi
I used RainX for a while but now I prefer a little light wax (currently NXS), works great, never used clay on the glass. seems pretty clean, the light cleaners in the wax seem to remove anything on the glass.
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
DerrickW
Nov 15, 2015 05:52 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
