Porter Cable and Zaino
I searched for a thread on this subject but it seems no one has asked this question.
I have a 05 NBP. Yes I know, SWIRLS. So to make this really short. I just bought a PC 7424 and would like to use Zaino.
I just bought the Fusion Z-PC Fusion swirl remover and will do the regular Zaino regime after that.
Pads? What are the best pads for the process. Any help would be great! Thanks!
Pad selection/product is dependent on the severity of the swirls .... I would start off with a light polishing pad and then move up probably to light cutting pad. There are several pad manufacturers and these seem to be the more popular ones; Lake Country, Propel, Edge, Sonus. Kits and single pads are available from online sites such as Autogeek (Lake & Edge), Exceldetail (Propel & Erasure), Autopia (Sonus), Detail City (Lake & Edge) and TOL (Lake). Hopefully this helps you a little bit and not confuse you.
the trick to using the PC with zaino is applying a whisper thin layer by using a buffing pad. I did that and used very little.
Originally Posted by paradigm
just to make sure it's clear...it isn't recommended using the PC to apply zaino sealants...just the ZPC itself. you would waste a ton of product to get it on the vehicle w/ the PC.
.02
.02
follow the info in this link, i barley used any zaino (about 95% full bottle) and i got excelent results
http://www.autopia-carcare.com/zaino.html
cycdaniel
12-17-2019 10:58 AM
