Porter cable DA polisher?
So awhile back I bought a cheap harbor freight polisher
http://www.harborfreight.com/7-inch-...:referralID=NA
And I'm kind of a novice detailer. Anyways been reading around some and have read a lot of people say only to use a DA polisher not the cheap harbor freight ones because its easy to burn through the paint. Anytime I use it I'm always keeping it moving not sitting in one spot just curious if getting something like the Porter cable DA polisher is worth it or necessary or is the harbor freight one sufficient ?
Werd. Same here, except I have not gotten to use mine yet but I am super ready too!
I have a similar cheap polishers, but got a Griots Garage 6" polisher and i did an pretty damn amazing job my first time!
Not only can you burn the paint but unless your very skilled with it you can end up with holograms from hell that are tough to get out.
If your car is a medium to light color you may not be noticing the holograms.
PC is the only way to go.
Why won't the PC burn the paint and the other one will?
Well if that's the case then $118@Amazon for the correct tool is pretty cheap IMO.
Read this .. it might explain it better
http://www.meguiarsonline.com/forums...ital-Polishers
Thanks guys .ya guess I. Should just spend the 100 and get the right buffer.don't wanna mess the paint up.also think I might try that black fire wet diamond stuff
cycdaniel
12-17-2019 10:58 AM
BoricuaTL
04-08-2016 01:08 PM
SinCityTLX
55
10-11-2015 01:20 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
