PC Swirl Removal Help Uggg
Doesn't Rice His Car
1 Post
First of all, I'd like to say it's a TOTALLY different ballgame when you're working on a black car.
So today, I decided to put the PC to use on my Black TSX. Ugg what a PIA. I started off with a Orange erasure and optimum compound. It did a semi-descent job in removing some of the swirls, however, I can still see some fine swirl marks in the sun. I'm guessing my next step is xyz product on a white pad?
Also, there are a few medium scratches on my car (just a few sporadic ones), that just won't come out using the combo above. I know supposedly they're suppose to come out as long as you can run your fingernail over it and it doesn't catch. How the heck am I suppose to get those out. they're not really TOO noticeable, but they're there. Should I bump it up to a yellow pad?
Picture of said scratches here..
http://img267.imageshack.us/img267/1364/scratchhx2.jpg
And finally WTF is up with the optimum compound I'm using. The stuff just doesn't friggin break down. According to the videos I watched before I started, "Work the compound for ~3-5 minutes until broken down, and do not exceed 4500 rpm."
http://www.autogeek.net/dual-action-polisher.html
The stuff just doesn't break down. I worked it for like 10 minutes and it was still somewhat "wet." It's not like I'm using a crap ton either. I just put an 'X' on my pad per door panel.
I'm at the point where I just want to cash in all my chips and pay someone to do this shit.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Former Sponsor
Stud, OC does break down, your probably just not use to it. And 3-5 minutes is plenty. You may be waiting for it to haze, which isnt going to happen. All Optimum polishes have high levels of lubricity. The only way you can tell if it has broke down is to remove the product and inspect your results. If the swirls are gone, good job! If there not, add a "little" and do it again......
Cardinals rules of PC'ing. Learn the machine, learn the product, learn the pad, then learn ever conceievable combination of the above and how they work together!
Originally Posted by Bambo2888
ps- paint correction only occurs at 5000 rpms and up. lower rpms are simply for application and removal.
I'm new to this. Can you explain what is paint correction?
Former Sponsor
Correct away..............
they go wooooot wooooot
1 Post
Needs more Lemon Pledge
run the PC at 5 or 6 in the affected areas and you will get better results. Watch out for sling, though... How do I get Optimum polish off my garage ceiling?
Originally Posted by Hawhyen51
Patience is a virtue . . . take your time. Optimum stays pretty much clear throughout the working process. Great tips from the previous posts.
My limited experience (see above post), when your arm feels like jelly. You have to guess, wipe it off and check the results.
Former Sponsor
Originally Posted by Master47
If OP stays clear throughout the process...how do you tell when it actually breaks down and it's finished and ready for buffing?
Originally Posted by exceldetail
When you polishing or compounding, your "buffing".....
I think my biggest problem is that I try to do too large of a panel at a time (i.e. - half the hood) and parts of the area I am working on starts to dry and I end up "dry-buffing" creating holograms.
Former Sponsor
Optimum polishes, with the exception of PoliSeal wont dry on you. If your dry buffing with Optimum Polish or Compound, and your getting buffer trails, your not using enough product. A good polish will always leave some lubricity between pad and paint. It waits for you to get one, you dont wait for it...
As for determining "when" its completely broken down, its a trial and error mission. Find a method that incorporates the polishes break down period, in conjunction with swirl elimination, and your on the road to total surface prep. The only way your going to figure this out is to buff small areas once, and wipe. Then twice and wipe. Do you need to buff an area 3 times? You wont know until youve looked at the results of buffing it twice! Every polish and compound are different. Ive narrowed my buffing products down to two manufacturers, Four Star Body Shop, and Optimum. Either of these will satisfy my needs.
I can never say this enough.
Understand the following:
Get familiar with the machine, know the pads ability, choose quaility products and get familiar with the characteristics of the product. Then throw all 3 together and start over!
And when in doubt, call me!
As Patrick said, it's basically trial and error with OP. Take the hood for example, I'll separate it into 4 sections and do each section one at a time. I'll do a two pass (horizontally and vertically), wipe down, reevaluate, and if necessary repeat the process. I have polishes from several different manufacturers for different needs. It's just a matter of getting familiar with each product and trying to find the right combo for the job.
dainmezron
10-16-2015 06:56 PM
SinCityTLX
55
10-11-2015 01:20 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
