Need opinion
Old Mar 16, 2008 | 03:14 AM
xaznperswaesonx's Avatar
Need opinion
Need opinion:
I first start out washing and claying the car.
The use a Fine-Cut Cleaner from meguire with a buffer.
then wash then follow up with Show Car glaze polisher
Then wash wax with NXT Gerneration Tech Wax , then wash, wax, and finally wash.
Was removing slight swirl mark that developed over the season from driving.
I do this twice a year, one at the beginning of fall, and one at beginning of spring.
Old Mar 16, 2008 | 06:22 PM
bo0sty's Avatar
i dont think you need to wash each step, i dont think your suppose to wash after you polish either
Old Mar 16, 2008 | 08:32 PM
Fulani has a TL's Avatar
Wash before you clay, then if you want after you clay; then your onto all your cleaners, polishes and what nott. No need to wash in between polishes. You may actually introduce damage that you just removed/corrected
__________________
Kansas City/Missouri Meet!!!
Old Mar 16, 2008 | 09:34 PM
Jesstzn's Avatar
Originally Posted by xaznperswaesonx
Generation-Tech-Wax-Paste]NXT Gerneration Tech Wax[/URL] , then wash, wax, and finally wash.
Generation-Tech-Wax-Paste , then wash, wax , and finally wash.
You mention a wax ( see red above ) what is it?
Unless your doing these steps on different days no need for all the washing.
Old Mar 17, 2008 | 02:27 AM
wax = generation tech wax paste .. just applying two layer. and i read some where that the you should wait 24hrs before you apply a 2nd layer?
Old Mar 17, 2008 | 07:35 AM
exceldetail's Avatar
Former Sponsor
Too much washing!
Wash, clay, polish, wax (seal), wallah.........If you desire two coats, i would apply a second coat after your next wash.......
Old Mar 17, 2008 | 08:32 AM
Jesstzn's Avatar
Ok that clears it up .. the way it was written it looked like the wax was a diffent wax then the NXT.
If you apply a second layer it will be nore for coverage cuz from what I understand NXT has cleaners in it and the second layer is going to remove a portion of the first.
Old Mar 17, 2008 | 11:19 AM
from what the product discrption says, it's not a cleaner. i think you must be refering to the normal cleaner wax
Old Mar 17, 2008 | 11:38 AM
Jesstzn's Avatar
I am very familiar with NXT .. I was one of the testers of it in Canada.
When it can remove some oxidization , and it does, it has cleaners in it.
Thats why its an OYC one step type product.
Old Mar 17, 2008 | 11:54 AM
Former Sponsor
First generation Tech wax contains mild cleaners. Im not certain of Gen II Tech wax though.
Old Mar 17, 2008 | 11:59 AM
vinnier6's Avatar
would it be ok to use the first gen nxt as a final product after some polish/swirl remover...
so my process would look like this...
wash
clay
polish..udm
nxt..udm
Old Mar 17, 2008 | 12:34 PM
Jesstzn's Avatar
wash
clay
polish..udm
nxt..udm
Don't see why not as long as they are polishes and not glazes.. NXT if fine ... just a rather short life for the first generation.... but hey .. its so easy to apply/remove you can do it every 2 weeks.
I don't apply NXT with a pc/udm.. takes too long .. faster by hand and us less and no pad to wash.
Old Mar 17, 2008 | 12:59 PM
Hawhyen51's Avatar
Pat, I was digging around the Megs forum and there were a couple of threads about NXT 2.0 but couldn't find a post explaining the differences between the two. I would assume it would still have the mild cleaners along with the New Hydrophobic Polymer Technology, incorporated into the new formula. The same thing used in their Ultimate Quick Detailer. It supposedly gives it a slicker and smoother surface. Nothing on durability, tho.
. . . provides relentless water beading and protection against oxidation, corrosion, UV rays and surface degradation.
Old Mar 17, 2008 | 01:41 PM
Jesstzn's Avatar
Good work
Old Mar 17, 2008 | 03:27 PM
ah thanks for the info .. so no point in putting 2 layer of nxt .. just 1 layer of nxt and 1 layer of carnuba?
Old Mar 17, 2008 | 03:57 PM
Jesstzn's Avatar
Second layer won't hurt just for coverage purposes .. then the carnuba as long as it isn't a cleaner carnuba.
Old Mar 17, 2008 | 04:04 PM
vinnier6's Avatar
can i not get better results with udm and the nxt then doing the nxt by hand....i was planning on using pinnacle advanced finishing polish or the swirl remover, then the nxt all with udm...any comments on the pinnacle...
Old Mar 17, 2008 | 04:52 PM
Jesstzn's Avatar
No comments on the Pinnacle cuz I have never used it but regarding the NXT it doesn't have abrasives and you have already done your cleaning with the Pinnacle so there is no real benifit mechanically.
You will just use more NXY .. still have the small noons and crahhys to do by hand and have a pad to wash.
JMHO.
Old Mar 17, 2008 | 09:11 PM
vinnier6's Avatar
JMHO.
thats cool, and you said i can layer a nuba on top of nxt??? is that a good thing to do...i am just trying to get by with what i have on hand as of right now, and the package i ordered comes with some pinnacle polish so i am going to give that a shot as well...on hand i have nxt, meguiars step 3(nuba), and some meguiars cleaner wax....
Old Mar 17, 2008 | 09:16 PM
Jesstzn's Avatar
No .. you can layer sealants and NXT is a sealant but it has cleaners in it so when you apply layer 2 of NXT your removing some of the first.. Carnubas can't be layered, you can put 10 coats of carnuba on and in the end you might have just a little more than 1 coat left ..
Old Mar 17, 2008 | 10:56 PM
bah .. cant seem to get swirls to go away .. any suggestion?
Old Mar 17, 2008 | 11:18 PM
bo0sty's Avatar
get aggressive?
Old Mar 17, 2008 | 11:20 PM
Jesstzn's Avatar
What buffer you using? Color of car?
Old Mar 18, 2008 | 04:59 AM
black car ... dewalt not sure of the model .. borrowed it from uncle. using a foam pad with the fine cut cleaner, then clean out foam pad aand resuse for the polish .. then a cotton pad to remove nxt wax (yes i know im lazy)
after the clean and polish, looks like swirls are gone. i was thinking maybe the cotton pad to remove wax is causing it but not sure.
Old Mar 18, 2008 | 08:02 AM
vinnier6's Avatar
maybe your foam pad doesnt offer any cut...i would try to get a fine-med cut pad...if the pad offers no cutting, then your fine polish is not going to do much in the cutting dept....
Old Mar 18, 2008 | 08:29 AM
Jesstzn's Avatar
Is it a rotary buffer?
Old Mar 18, 2008 | 12:47 PM
yup
Old Mar 19, 2008 | 01:41 AM
well i think i kinda solved the issue, seems on my car, the swirl was from the removal of wax with the buffer.
hope its the same with wife's car.
HOWELLiNC
Wash & Wax
35
Jul 16, 2017 04:13 PM
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
eastcoastguy
Sep 23, 2015 06:29 AM
dlknight
Sep 3, 2015 07:54 PM
