machine Polisher?
Old Aug 26, 2009 | 02:29 PM
j1n's Avatar
j1n
machine Polisher?
Is this a good machine polisher for a noob?
http://www.harborfreight.com/cpi/cta...emnumber=92623
looks like a good price.
Reason i want to get a machine polisher is cause bout 2 weeks ago i decided to try and detail my car for the first time. i washed, clayed, then rewashed and then when i went to polish (by hand) it wasnt doing anything for the swirls and light scratches. so i just skipped it and waxed.
Also what kind of pads should i use?
Old Aug 26, 2009 | 03:44 PM
n0rm's Avatar
I ♡ PEK PEK
for a noob I would look into the Porter Cable or the Flex if you can afford it.
Old Aug 26, 2009 | 03:56 PM
exceldetail's Avatar
Former Sponsor
7424XP, probably all you will ever need, and priced right as well.
Old Aug 26, 2009 | 04:46 PM
Jesstzn's Avatar
For a noob that machine will get you into more trouble than your trying to correct ... go with a PC.
Old Aug 26, 2009 | 05:22 PM
CocheseUGA's Avatar
It's cheap for a reason.
Old Aug 26, 2009 | 05:36 PM
j1n's Avatar
j1n
Will the erasure 6.5" pads on your site work with that polisher?
also which pad is best to get out light scratches? should i use a yellow followed by white? or orange then white?
Old Aug 26, 2009 | 06:29 PM
j1n's Avatar
j1n
OK so ive been doing some more reading and hows this combo sound
7424XP Polisher
Orange and Yellow foam pads
Opt Compound II
Opt Polisher II
is that good?... am i missing any thing?
Old Aug 26, 2009 | 06:53 PM
n0rm's Avatar
I ♡ PEK PEK
You're going to need white and gray pads esp. on a dark colored car.
Old Aug 26, 2009 | 07:02 PM
05_NBP_TL's Avatar
HE>i
7424XP Polisher
Opt Compound II
Opt Polisher II
...and make sure you have plenty of pads (3 orange, at least 4 white, and maybe a red or black) , also have patience getting to know what each polish/pad combo gives the best results for you. Always seal up after polishing. Be sure to check out Exceldetail and DetailedImage for products and info. Both are excellent vendors on here.
Old Aug 26, 2009 | 07:32 PM
j1n's Avatar
j1n
thnx for the info guys. i will do more research also.
Old Aug 26, 2009 | 08:20 PM
Former Sponsor
I would opt for the 5.5" pads as they provide better control and are actually easier on the machine. Just an all around better size when polishing.
If it was me...........
2 Orange
2 White
1 Black
1 Red
(1 yellow if $ permits)
Dont forget your discount as well!
You might want to consider the Danase line as they are on clearance as well! Could save some good cash! They are excellent polishes (Ive used them), not quite Optimum, but they are very adequate for most situations! And if your budget is limited, its a thought. Dont skimp on a sealant though! Highly suggest Four Star UPP or DG 105, Optimum Spray Wax or Glanz Wax......
Old Aug 27, 2009 | 02:04 PM
vinnier6's Avatar
its been my experience that acura paint doesnt need an orange pad....i would think white and gray will be all you need.....
SinCityTLX
55
Oct 11, 2015 01:20 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
ceb
ILX
Sep 27, 2015 10:56 AM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
