Langka - chip repair - tried it
I got my first significant chip in my CL over the last few weeks. (Big road trips to Syracus and the White Mountains.) I purchased Langka awhile ago via the net and gave it a try. It's easy to use and works well. I'll pass on a couple of tips. In short, to use it, you apply touch-up paint, let it dry and then remove the excess paint using Langka. The product smoothes out the repaired surface so there is no excess paint left behind.
Tip #1. Do not use Honda/Acura touch-up paint. Why? The way it dries or rather does not dry or cure makes it problematic when used with Langka. Just use Duplicolor touch-up paint. It dries fast and works well with Langka.
Tip#2. Get micro-fine paint brush. Langka sells them on their site. Allows you to applying touch-up paint with surgical accuracy.
So, I give Langka a big thumbs up. Chips are going to happen and this helps to repair them pretty well.
Paul
Paul
I'm Baaack!
Langka - Cause chips happen!
Originally Posted by Average Jose
lanka is all right. I have trouble with it becuase often it removes the paint in the chip
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
Hines57
09-24-2015 01:58 PM
