how to really clean the wheels
Old May 24, 2004 | 11:18 PM
DjElucid's Avatar
I have some tough dirt/dust/oil, whatever it is stuck on my rims and it really bothers me. I bought one of those hard little brushes with hard bristles and it still isn't coming off.
What's the best wheel cleaner out there to get that stuff off??
thanks!
Old Jun 14, 2004 | 09:01 AM
crisco's Avatar
Just bought some McGuires spray alloy wheel cleaner (in the pink/purple bottle). Just spray on wheels and rinse off with the hose. Works great - got rid of the junk on my rims that I couldn't remove with a brush!
Old Jun 14, 2004 | 09:11 AM
Dan Martin's Avatar
Photography Nerd
I use the same stuff and it works great!
Old Jun 14, 2004 | 07:06 PM
Sturm's Avatar
TSX Bronco
I think I'm a Meguiar's product whore. I think I own almost every product they produce, including the wheel cleaner. Just got my NXT wax in the mail today. I hope it's nice out this weekend so I can try it out!
Old Jun 15, 2004 | 07:34 AM
Brooks's Avatar
I own a Suzuki sportbike and use Pro Honda Polish to clean that and decided to use that on my wheels. I had some stuff on there that wasnt coming off with with a soapy water mixture and a sponge. I sprayed it on there and wiped it off and everything came off great.
Old Jun 15, 2004 | 08:18 AM
Helicobacter Pylori's Avatar
I'm allergic to bull
Is there a place I can buy Meguiar's product online?
Old Jun 15, 2004 | 10:59 AM
DEVO's Avatar
I assume you mean on the inside portion? Wire brush sort of clued me in... anyway, do a search here. The way I solved this issue was to have the inside portions painted. That way it's harder for stuff to stick on.
Old Jul 10, 2004 | 10:40 PM
bgillette's Avatar
SOAP AND WATER.....and a soft brush like you would use on your paint.....
if it gets so dirty that you need to spray stuff on it.........you need to CLEAN YOUR CAR MORE OFTEN!!!!
Old Jul 10, 2004 | 11:27 PM
CDR's Avatar
CDR
I use Eagle One A2Z wheel cleaner for a major wheel cleaning -- works great, and is available at many places. I use a soft brush only; many wheels are clear coated, and a stiff brush will damage the protective coat.
However, I don't need to use it very often -- here's why. About 8 months ago, when I got my TSX, I took the wheels off, cleaned them (A2Z), and then put 2 coats of Zaino sealant on them (have also used Meguiar's #20). With the sealant in place, my normal car wash solution and a soft wheel brush gets everything off. In fact, using a strong wheel cleaner would take the sealant off.
I recommend this Autopia tutorial on wheel cleaning: www.bettercarcare.com/articles.php?articleId=41
Old Jul 11, 2004 | 05:51 AM
floridaowner's Avatar
i clean the wheels once in a while. it is quite difficult to keep them clean beacuse once you start driving again the dirt comes back quickly.
Old Jul 26, 2004 | 04:01 PM
Dr. Daryl's Avatar
Anyone remove their wheels to clean them?
Given that there is a lot of visible wheel unreachable from the outside, does anyone remove their wheels to clean them?
My driveway is sloped significantly so doing such would be dangerous.
However, I'm very tempted to hop over to the pop-in-law's house and do this from time to time.
............or am I getting flaky............???
Dr. Daryl
Old Jul 27, 2004 | 05:04 PM
Arcticcl9's Avatar
Can't wait to drive
I do my own tire rotations because I can clean the inside of the wheels at the same time. I still get them dirty often though (every 3000mi isn't enough to keep the inside of the wheels clean)
Old Jul 27, 2004 | 05:08 PM
djtrancetastic's Avatar
Battousai the Manslayer
Nothing and I mean Nothing takes off brake dust like Simple Green and fresh water. I also use Meguiars
Old Jul 27, 2004 | 05:17 PM
ccarbajal08's Avatar
OCD in the OC
Good idea man. But, what about balance? Do you also balance your tires? I'd like to take me wheels off when I rotate so I can clean inside also.
Old Jul 27, 2004 | 05:33 PM
CLpower's Avatar
teh Senior Instigator
Eagle One A2Z is BY FAR the best wheel cleaner i've ever used. Throw it on, agitate the stuff a little bit w/ a mitt and hose off. I've used it to make wheels that hadn't been cleaned in a YEAR look spotless.
Autozone has a special 2 bottles for $5.99 (regular $4.99) I stocked up and bought 10 bottles :o
Old Jul 27, 2004 | 05:34 PM
CLpower's Avatar
www.meguiars.com
Old Jul 27, 2004 | 05:35 PM
CLpower's Avatar
I thought the same till I used A2Z, I had been using Simple Green to clean wheels for YEARS until I tried this stuff. I still use SG on customers cars because it's so cheap though.
Old Jul 27, 2004 | 07:18 PM
True...
Old Jul 29, 2004 | 09:09 PM
TSXtc's Avatar
P21s
P21S tire and wheel gel. Or Eagle one A2Z. For a finished look I like Einszetts Tiefenflager. Leaves it shiny but not too shiny and leaves no film on tire.
Feb 25, 2020 09:57 AM
KB1_EJ6
Nov 13, 2016 09:51 PM
nanos
Nov 12, 2015 08:41 PM
lland
Oct 4, 2015 04:47 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
