How often to polish?
Old Jul 11, 2009 | 02:07 PM
db1234's Avatar
Just wondering how often it is to safely polish your car with a PC? My understanding is that each time you polish, you are taking off a tiny layer of clearcoat, so is there a limit as to how often you can do it? Also, because a tiny layer of clearcoat is removed, isn't the overall paint protection diminished with each polish? I guess I am just wondering if 10 years down the road, while the paint maybe swirl free and look good, it is half the thickness of when new.
Old Jul 11, 2009 | 02:58 PM
rlerman's Avatar
I only do it when it needs it, when I see defects on the paint. Every 4-6 months or so I will clay and re-wax the car, usually I go by how much water beads on the car.
Old Jul 11, 2009 | 03:10 PM
exceldetail's Avatar
Former Sponsor
Usually a couple times a year is suffice (for a light polish, not serious compounding). Yes, its true, you are removing a very minute amount of clear, but normally not enough to suffer any consequences down the road. Using a PC removes far less then a rotary would as well. Keep it protected with a sealant 24/7, use spray waxes monthly, and keep your washing techniques in order and you will end up having to polish less then a couple times a year even. Another alternative is to use a paint cleaner every other time with the PC. This will help brighten the paint with no abrasives.
Old Jul 11, 2009 | 10:08 PM
csmeance's Avatar
I do a full detail on the car's about once a year, that includes polishing. Use proper techniques and you won't need to polish at all!
Old Jul 16, 2009 | 10:47 PM
Edu_Jas1989's Avatar
4th Gear
i tend to wash and wax my car as much as possible, i used to wax machines for work so i tend to put light coats and always use clean towel
BoricuaTL
Apr 8, 2016 01:08 PM
vtec314
Nov 7, 2015 08:20 AM
SinCityTLX
55
Oct 11, 2015 01:20 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Mikehxbx
Sep 27, 2015 08:58 PM
