How to get rid of Sandpaper marks
Old Jul 22, 2011 | 02:12 AM
Toddy's Avatar
Registered Member
Washed my car today and it looks like someone rubbed sand paper all over my hood. They aren't deep scratches but they are definately there. What do you guys recommend I do to get rid of this?
Old Jul 22, 2011 | 02:43 AM
TOGWT's Avatar
The Old Grey Whistle Test
Grit rating: this is the level of scratches made on a paint surface by finishing paper on newly applied OEM paint on the production line i.e. before it has been oven dried and cured The grit rating on an abrasive or polishing pad is an indication that a product is designed remove the surface scratches left by finishing paper i.e. 2500 grit scratches are removed by a 2500 grit rated polish) it doesn't mean that it is a 2500 grit level abrasive. To remove these scratches would need a finer grit (>2000 grit).
If you match the polish / pad to the equivalent grit (scratch) mark it will remove them i.e. Menzerna polish PO 203 will remove 2000 grit marks (scratches) along with a polishing pad
Old Jul 22, 2011 | 02:52 AM
Toddy's Avatar
Registered Member
So Im going to need a high speed buffer? What kind of pad should I use
Old Jul 24, 2011 | 03:03 AM
TOGWT's Avatar
A lake county (LC)White polishing pad
Old Jul 24, 2011 | 10:56 AM
pttl's Avatar
My first Avatar....
Is the LC white more aggressive than the orange?
Old Jul 24, 2011 | 01:36 PM
wong05tsx's Avatar
Need more room in
Less aggressive
I've found the orange pad to go very well with a orange (on acura paint). Followed by PO85RD finishing polish on a white/blue at a slower speed.
Old Jul 25, 2011 | 03:47 AM
TOGWT's Avatar
Dictum: Always start with the least abrasive first
snorf
Nov 4, 2019 06:44 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
c1souk
Sep 28, 2015 11:20 AM
carz0159
Sep 20, 2015 06:11 PM
