How Do I Remove These Surface Scratches?
Slicker Than Your Average
I have two small surface scratches ( you can't see them at certain angles and they don't “catch” my fingernail ) on my two month old 2007 Acura TL and I just wanted to know how I would go about removing them?
I’m a total noob when it comes to scratch repair so would I be better off going to a professional? I tried Meguiar’s Scratch X, but it didn’t do anything ( maybe I didn’t apply it right, I don’t know ). Any input would be greatly appreciated.
Scratch 1
![](http://i150.photobucket.com/albums/s111/Frondiculous/2007%20Acura%20TL/Scratch1.jpg)
Scratch 2
![](http://i150.photobucket.com/albums/s111/Frondiculous/2007%20Acura%20TL/Scratch2.jpg)
Scratch 2 ( Close-Up )
![](http://i150.photobucket.com/albums/s111/Frondiculous/2007%20Acura%20TL/Scratch2Close-up.jpg)
Thanks again!
Scratch 1
Scratch 2
Thanks again!
Former Sponsor
Well those are pretty itty bitty to say the least! I would go at it again with the Megs ScratchX, and go with the grain. Take the scratchX, and apply a small dab, about the size of a pea. Rub gently, yet with enough pressure, the same direction as the scratch. Keep going until the scratchX dissapears, then wipe away and take another look, You may need to do it a couple few times....What your going to do is abrade that vertical edge down so it doesnt catch any light and reflect it back to you, which makes it visible. You may get additional marring if you go at it to hard, so only use enough to abrade that edge off.....
Then follow up with some protection in the way of a sealant or Nuba....
Excellent pics by the way, a star student no doubt!
1. Apply the product by rubbing in the direction of the scratch.
2. Let the product dry.
3. Wipe off the excess.
4. Repeat if necessary.
How long should I wait between applications? Thanks again!
they go wooooot wooooot
1 Post
You can actually go ahead and reapply immediately until the scratch is to your standards. Nothing needs curing, so you should be OK.
BTW, that first pictures is amazing, the paint is a beautiful color.
Former Sponsor
The drying process is totally useless.......lol. Its not doing anything while its drying..
Use the process descibed above, repeat if necessary (As bambo also suggested)...
i actually have two scratches similar to that and they do not come out with scratch X no matter how many applications i put on. what is the next step????
Former Sponsor
The compound is a little heavier then the SX. You could probably get the scratches out with the PC and ScratchX with a PC, if there in an area easily accessible.
Again, a PC is the tool needed/proper starting point for proper surface care.
Hey guys, does the meg scratch x remove swirl marks too? what products do you recomment for removing light swirl marks on a NBP. the long weekend is coming up and i want my car to look its best. thanks for your help in advance.
https://acurazine.com/forums/wash-wax-23/swirls-361296/
https://acurazine.com/forums/wash-wax-23/pc-swirl-removal-help-uggg-358115/
https://acurazine.com/forums/wash-wax-23/easiest-products-newbie-use-354878/
https://acurazine.com/forums/wash-wax-23/whats-your-arsenal-343438/
SinCityTLX
55
10-11-2015 01:20 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Hines57
09-24-2015 01:58 PM
