How Do I Remove This Spot?
Old Jul 15, 2007 | 03:08 PM
S L I C K's Avatar
Slicker Than Your Average
(1) What might have caused this white spot and (2) how would I go about removing it?
No matter how much I wash it, it doesn't seem to come off. Any ideas guys? Thanks a lot in advance.
Old Jul 15, 2007 | 04:31 PM
S L I C K's Avatar
Anyone? Could it be a water or soap spot?
Old Jul 15, 2007 | 05:16 PM
S L I C K's Avatar
Maybe it's a rock scuff? I really don't know what it is. I don't feel anything when I run my finger over the white spot.
Old Jul 15, 2007 | 08:41 PM
stogie1020's Avatar
Needs more Lemon Pledge
Give the 50/50 vinegar/water on a MF a try. Let it soak in for five minutes or so (just leave the towel there) and see what happens... If it's minerals from water, that should do it. Do you have any Klasse AIO or other chemical paint cleaner to try? Next up, abrasives?
Old Jul 15, 2007 | 08:45 PM
triggerman's Avatar
It looks like it may be a bug you hit.
Old Jul 15, 2007 | 09:40 PM
exceldetail's Avatar
Former Sponsor
Bird dropping maybe. Im with Stog, hit it with some paint cleaner.....
Old Jul 16, 2007 | 06:59 AM
jwclements1's Avatar
I just use P21s polishing soap on that metal
Old Jul 16, 2007 | 08:50 AM
S L I C K's Avatar
Is Meguiar's Deep Crystal System Paint Cleaner good enough or should I try something else? Also, do I just rub the spot with the paint cleaner until it goes away?
Old Jul 16, 2007 | 05:09 PM
stogie1020's Avatar
Give the Megs a try on a foam applicator or Terry applicator. If you have a PC then go to town. If you don't see any noticeable improvement after a few minutes of work, you will probably need to try something more aggressive, like a true polish.
Old Jul 16, 2007 | 05:21 PM
S L I C K's Avatar
Thanks! Also, I have very very very fine scratches in the black rubber (?) accents around the windows and I wanted to know if there was a way to get rid of these?
mlody
Dec 4, 2019 02:11 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
dainmezron
Oct 16, 2015 06:56 PM
lowgrowl
Sep 26, 2015 05:18 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
