How to Clean Muffler Tips
I use some Turtle Wax Chrome polish and it does a fine job. You can also use the powerball that attaches to a drill too but I find doing it by hand works just fine.
any metal -chrome polish
See the Off Topic section - wash and wax for threads on the subject
AZ Community Team
Received 7,771 Likes
Eagle One (Never Dull?) or Mothers Mag & Aluminium polish.
Any polish, and if the inside looks deteriorated, just tape off the chrome and spray with a high temp flat black paint. I keep outside grille spray paint in the garage for the mufflers on the Mazda and have used it on the Acura, not only teh inside of teh tips, but on the mufflers themselves.
Agreed. That's what I use for my tips. Works well for taking of the carbon build-up and any other gunk too. Not to mention you will probably only end up buying one can of it, stuff lasts forever. I'm still barely below the top, just use enough of the wadding to get the job done.
What do you use it on in the house? Never thought of that.
wow this forum is so bad on my wallet! I hate you all.
I'm leaving the comfort of my couch and tv to go buy this Never Dull.. my tips are awful.
Thanks!
Thanks!
Got it, Luv it! THANK YOU!
If you need more bite to the metal polish, you can apply it with some 0000 grade steel wool. Then I'll typically follow up with another coat using a foam applicator pad. The steel wool really helps cut through old grime, oxidation and contamination.
George
George
DerrickW
11-15-2015 05:52 PM
johnpancakes014
09-27-2015 12:58 PM
