How to black out the moldings turned white...
How do, if there is a way, we get our moldings and weather seal around the sunroof back to black again? I dont really see myself popping it all off and buying new ones from Acura...I don't know the rep of this "back to black" crap i saw in Autozone... thanks for the help
Bonki' Ehrite!
Former Sponsor
Are you referring to the felt trim around the sunroof on the exterior? For door weatherstripping, einszett Gummifledge is excellent, and anything that needs renewing I go for Black Wow.
The trim around the exerior on my sunroof is waxed and weather beat, like almost faded.
2) the cowl of my windshield wipers is turning white
3)the actual weather stripping in and around my outside windows is kinda getting faded
and 4) the inside wheel wells are all jacked up from mud and dirt. How woudl you detail or fix this?
Here is the prblem...
2) Black wow, back to black, etc. Use sparingly and do it in multiple passes
3)see #1
4)a degreaser. My preference is Megs APC.
The trim around the exerior on my sunroof is waxed and weather beat, like almost faded. First use and APC and a soft cloth then apply a dressing to it , in future keep the wax away
2) the cowl of my windshield wipers is turning white How old is your car?
3)the actual weather stripping in and around my outside windows is kinda getting faded Wipe it down with rubbing alcohol untill no more black transfers to the cloth then dress it
and 4) the inside wheel wells are all jacked up from mud and dirt. How woudl you detail or fix this? Is it plastic in there or textured?
Bonki' Ehrite!
1. Back to black, apply with a small brush....and tape up before waxing in the future.
2. Back to black, apply with microfiber.
3. Back to black.
4. Get a scrub brush and Formula 88 degreaser (6 bucks per gallon at Home Depot) and use a spray bottle. Apply liberally and scrub away. Repeat two, maybe 3 times, hosing off in between, and then dress with a spray tire shine.
My process for number 4 may be unheard of, but I swear it works. I do it on my car, and my customers cars.
3. Back to black.
The car is an 06, and the wheel-inners are like carpeted type deals...The cowl around the wipers is like sun faded, and wax stained it seems. It was from the previous owner, Id like to start fresh and keep it looking good-after I spend millions of dollars to rejuvenate the weathered and neglected pieces I mentioned in this post.
Former Sponsor
When I use it all up, I'll be looking out for a new product to try. Black Wow is the leading candidate.
Although, it looked much better when I did it on the Accord rocker mouldings. I wonder if it's a 'less is more' kinda deal. The CR-V will get a new coat this weekend under that theory.
Question - is there a way to remove stuff like this, or do we wait until it fades?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Fade to Black, also my favorite Metallica song
I have an 06 that sits outside, and this part of the car really seems to fade quickly in the sun. The black turns to dark grey in just a few years. Kind of crappy uv resistance on Acura's part. Even cheap Honda Fits seem to have better black plastic cowl molding under the wipers. I too have a little bit of white staining from a lazy spray wax job. It will not come off. Any suggestions for removing was stains before I try to make the part black again? I wonder how much it would cost just to replace the damn part instead.
Bonki' Ehrite!
If you wanna clean it before applying, try giving it a LOT of attention with a brush while washing the car.
handsom-hustla
11-13-2015 05:04 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
Billu99tl
09-13-2015 11:30 AM
