Good starter pads
Hi........I just purchased the Porter Cable 7424 PC and was wondering what would be a good set of pads to go with it. The backing plate I measured was about 6". Would I use the 5.5" pads? Or perhaps 6"? I saw some nice sets of Lake Country pads on Exceldetail's website. Would one of these sets be good? I am somewhat of a beginner using a PC.
My TL-S is an 08 and the paint is new without scratches. I just want to keep it looking nice.
Thanks for any help.........
Actually spring for another smaller backing plate and yellow cutting pad .. 2 white polishing pads .. thats all you should need.
Here is a link to his backing plate
http://www.prestostore.com/cgi-bin/s...37932&pd=97903
Save the other PB to put on your cordless drill to spin dry the pads after you wash them.
Also grab the 8 oz sample bottles of Optimum Compound & Polish .. good price and lots for the weekender.
Ya .. I didn't add the black pad as I do all my LSP by hand .. outside of PoliSeal ..
I just find too much waste in the pad ... which prolly doesn't matter if your only doing your own car .. and you still beed to do some by hand anyway as the pad won't go in all the areas.
Okay, thanks for the advice. I think I'll get the set that has the 5.5" yellow, white and black pads. And get the 5" backing plate. I guess the one I have which I measured just shy of 6" won't work with the 5.5" pads?
I've also seen those pad cleaning machines where you just put your PC in the top and turn it on.......cleans the pads really quick. Are they worth it?
http://www.autogeek.net/system-2000-pad-washer.html
On the Optimum C/P.......when is that used in the detailing process?
Not trying to thread-jack, however are there any cutting pads out there that are of a thicker density then the orange cutting pad. I find even with two pass’s I am unable to get out most of the defects on surfaces I am working with (that’s two passes with Optimum Compound)
Theres always yellow, its actually less dense which allows more cell edges to come in contact with the paint, thus "cutting". Jess (I think) uses the yellow frequently.
Yellow is great on stubborn swirls and scratches, even better for water spots.
mada51589
Jan 9, 2025 04:40 PM
nanos
Nov 12, 2015 08:41 PM
