getting bumper clean
Old May 30, 2007 | 02:58 PM
pjoseph's Avatar
Any ideas on how to go about cleaning the front bumper that has bugs and other stains on it that are not comming off too easily.
It is a silver 3.2tl
Old May 30, 2007 | 04:10 PM
stogie1020's Avatar
Needs more Lemon Pledge
First, just let them soak for a little while to loosen them up. A MF towel wet with wash soap water should work. The just wash normally.
Second, try some Bug and Tar remover. This will typically remove any wax/sealant so reapply to the bumper when done washing.
Third (if the first two didn't work) hit it with a clay bar and lube. Re-seal/wax when done.
Old May 31, 2007 | 12:28 AM
mrhenchen's Avatar
i actually bought some tarminator, i followed the directions and doesn't seem too effective. is spraying bug and tar remover into a mf cloth the best method of using bug and tar remover?
Old May 31, 2007 | 12:38 AM
stogie1020's Avatar
Usually works for me. You sure these are bugs? How long were they on the paint? They can "etch" the paint if left on for too long. May need a PC and some polish... Try the clay bar first, though
Old May 31, 2007 | 12:41 AM
treez35's Avatar
i have some bug and tar off stuff, works great and smells like green gatorade
Old May 31, 2007 | 07:38 AM
exceldetail's Avatar
Former Sponsor
Let the bugs soften up a little with some water/soap. Adding the MF to the mix prevents the moisture from evaporating before its necessary. Still the best trick in the book, sound advice.
quanaman
Jan 9, 2023 07:33 PM
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
h22lude
Sep 27, 2015 06:22 PM
jmaxima03
Sep 27, 2015 10:22 AM
