Detailing questions
Old Apr 26, 2012 | 08:44 PM
alienstudio's Avatar
Detailing questions
I don't know much when it comes to detailing. What I do most of the times is just wash with Meguiar's Gold Class Car Wash and dry with Chamois Cloths.
As the car went through its first year winter, the paint isn't as smooth and i can feel little bumps on the surface.
I am looking for products, ( ones that can be found in Canadian Tires) that i would need to do a self detail.
Any recommendations on products and the procedures in using them will be very helpful.
Thanks in advance.
Old Apr 26, 2012 | 09:24 PM
vp55's Avatar
^To get the paint smooth as glass you will need a claybar, which will pick-up all the contaminants embedded on the clear coat. I think you should be able to find a kit at your local car part store.
I just tried out Optimum No Rinse (ONR) and highly recommend this for maintenance washes. Don't need much water and cleans very well. Just do a search for threads on it if you want more information.
https://acurazine.com/forums/wash-wax-23/new-formula-onr-vs-dirty-black-paint-850172/
How to Clay Bar ----> http://www.detailedimage.com/Auto-De...uide/Clay-Bar/
ONR Wash ----> http://www.detailedimage.com/Ask-a-P...imum-no-rinse/
Old Apr 26, 2012 | 11:02 PM
Jesstzn's Avatar
Thanks in advance.
First off .. get rid of the chamouis... they will marr the paint .. Can Tire has big blue microfiber drying towels .. 24 x 36 .. not cheap but you will appreciate it in the long run ..
Get a sheepskin mitt to wash with and as said above clay bar the car .. CT carries the mothers clay bar kit.
As for wax ... http://www.canadiantire.ca/AST/brows....jsp?locale=en
Old Apr 26, 2012 | 11:06 PM
mY sLOW UA6's Avatar
^^What he said lol
Ditch the chamois you are making more work in the long run.
Old Apr 26, 2012 | 11:37 PM
I thought chamois are suppose to do better than microfiber since they don't create any swirls?
I used to use microfiber but i found more swirls while using them.
Also, what should i use to apply any wax or sealant? And which goes first?
Old Apr 26, 2012 | 11:40 PM
Chamois tends to marr the paint, you shouldn't get any swirls from the mocrofiber if you are doing it right.
When you first go to dry your car pat it down first, then mist some QD on there and wipe it down, never wipe a car without any lubricant.
Sealent is applied before the wax but you need to give it time to cure before you can out the wax on the car, just use a hand applicator to aplly it.
Old Apr 26, 2012 | 11:45 PM
Listen to this guy!
he knows his stuff!
oh, and How did you come up with your user name again, Jesstzn?!?
Old Apr 27, 2012 | 07:06 AM
theedeadmau5's Avatar
i've never seen a chamois damage clear if kept clean
Old Apr 27, 2012 | 07:12 AM
^it does do damage!!!
have you ever seen your paint under the correct lighting!?
Old Apr 27, 2012 | 08:43 AM
Jesstzn's Avatar
A true chamois made from the shin of mountain sheep or the skin of a Chamois was the go to years ago but it has very little forgiveness and if the slightest bit of grit or anything gets under it it will mar. Throw a damp chamois flat on the hoos then try to pull it off without lifting it up. The resistance is unreal.. now put something under it and imagine what will go on.
Proper M/F towels made for drying will not mar if used properly and kept clean. Waffle Weave Drying towels are the best. There is also a bit of a learning curve to using them.
Apply sealants etc with the 4" yellow foam applicators. Wash the applicator right after using it if using a sealant or throw it away. Sealant first.
About 15 years ago when I bought the 1st computer for my daughter I was also learning to use it and I went to set up an account somewhere which needed a user name. At the time I was reading the Vancouver Province sports page and right next to it was the entertainment page ( including the strip bars ) and one bar was headlining a girl named Jess Tzn ( she was Oriental ). Jess Tzn was a play on words .. Just Teasing ... Anyway .. there is the story ... and no I don't strip and I am male .. and too ugly to strip.
Old Apr 27, 2012 | 08:52 AM
thanks for sharing.
ever since you shared, i always get a laugh when reading your user name.
mugen_kid
Nov 13, 2015 10:38 PM
rockyboy
Sep 27, 2015 05:27 PM
datadr
Sep 12, 2015 09:12 PM
asahrts
Sep 4, 2015 05:55 PM
