Concrete splatter removal?
Old Mar 2, 2014 | 03:23 PM
mdrolet77's Avatar
So... I just got my car washed only to find out that I have concrete splatter all over the car. I've looked around a bit for a way to remove it without ruining the paing for good and the closest thing to a safe removal involves vinegar and a spoon! I'm a bit sceptic about the aftermath of that method so did anyone try it or has another way that worked well? My car is black and I would enjoy a lot not having to repaint it just because I drove by some roadwork
Old Mar 2, 2014 | 03:43 PM
pohljm's Avatar
Clay bar?
Old Mar 2, 2014 | 04:05 PM
yoks032rs's Avatar
there should be a clear coat on the car, just use warm water and a light rub with a soft
cloth. See if that works.
Old Mar 2, 2014 | 06:06 PM
splew's Avatar
So is it like actual buts of concrete or just concrete residue?
If there's any actual concrete on the car, I would say pressure wash it off. If it's just residue, then I would try clay bar. If that doesn't work try machine polishing.
Old Mar 2, 2014 | 09:19 PM
Never Summer's Avatar
I would be very hesitant about using anything to "rub" it out, the sand in the concrete will scratch the paint pretty badly. Usually I use a trowel to take concrete off of paint, but that's also on a concrete pump. I imagine a plastic scraper would work but again not sure what that would do to the paint.
Old Mar 3, 2014 | 08:27 AM
C8N's Avatar
C8N
Hope this helps
http://www.autogeekonline.net/forum/...overspray.html
Old Mar 3, 2014 | 09:05 AM
mdrolet77's Avatar
I'll look into the back set thing seems like a better alternative than what I 've see un till now. It's just residue but I wouldn't even try clay or machine polish, it would be like throwing sand on the polisher and then use it on the car... I will have to wait for a while before I can try it since it's too cold to use the product, it would just freeze on. I'll give you feedback once I tried it out.
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
samson_420
Oct 8, 2015 01:47 AM
lowgrowl
Sep 26, 2015 05:18 PM
