Cleaning Rims
use a rim cleaning brush. I have one from meg's it does an oak job, but i paid a dollar for it a a garage sale.
When they're really dirty, I use Meg's Hot Rims and a brush ($4 from Target) to agitate and loosen the dirt and then I just hose them down. Seems to work pretty good for me.
If they're not that dirty, car wash in a bucket and a brush to agitate and then hose them down.
Just yesterday I took each wheel off, washed the inside of the rim, clayed it and then applied Four Star UPP. I am hoping that wheel cleaner and a rim brush will keep them looking new in the future.
Former Sponsor
Dang your dedicated Mic!!
Heres my newest answer to a problem area............
Further info can be seen here.......
You should remove the wheels and clean them annually. You can also clean/detail the fender wells with the tire off. But for normal maintenance, any of the above suggestions do work. I prefer brushes with feathered tips or a chenille wash mitt. I'm leaning towards the tool Patrick mentioned in the above post especially to get between the caliper and wheel.
Originally Posted by Nedim
to be honest I dont know how to take a tire off. SO i would need to find a brush i can use to clean with out taking the tire off.
Trucki!!
if you haven't done it before there will be alot of build-up. When I've have people specifically ask to clean that on their car I use a product that I haven't seen talked about on here. That can of spray brake cleaner works wonders. It takes layers upon layers off quickly
Originally Posted by micvog
Yesterday I used the tire brush and car wash soap on the fender wells, and sprayed them with Stoners' Trim Shine. Is that what you would recommend Hawhyen51?
the brake cleaner is ok for a factory coated wheel for cleaning in most cases. if you have aftermarket wheels with a painted surface, not a good idea AT ALL. applying the brake cleaner to that surface will wipe the finish right off. bad experience.
FTW
had my ronjon wheels mounted, the guy putting them on got some greese on one of th wheels. he thought a quick spray of brake cleaner would take it right off, it did; along with the paint on an entire spoke.
man i'd be LIVID if that happened.
