Cleaning PC Pads
Old Jun 4, 2006 | 07:39 PM
BRH's Avatar
BRH
BRH
Cleaning PC Pads
I thought that I posted this question earlier, but apparently, it didn't "take":
I used my PC to apply Mother's Reflections and now I'm having some problems in thoroughly cleaning the pad. What's the best way to clean this?
Thanks!
Old Jun 4, 2006 | 08:37 PM
aaronng's Avatar
Driver/Detailer
I found that I couldn't clean out ALL the sealant that was in my PC pad. So I designated that pad as the sealant pad. I still wash it after using it.
Old Jun 4, 2006 | 09:09 PM
picus's Avatar
A couple ideas:
1) Soak it in a sink with some hot water and woolite mixed in (regular laundry detergent woolite) for a few hours, then rinse and scub with a good brush.
2) If that doesn't do it, put it in the wash on warm with some non-fabric softener detergent then let air dry.
3) If that doesn't do it try a specialized pad cleaner (although at this point it might be just worth tossing it or using it only for that product).
Old Jun 4, 2006 | 09:30 PM
West6MT's Avatar
You could always consider applying by hand . I apply all waxes and sealants by hand. It really does not take long at all.
Old Jun 5, 2006 | 02:13 AM
exceldetail's Avatar
Former Sponsor
All purpose cleaner, and squeeze it like ya mean it!
Old Jun 5, 2006 | 01:32 PM
bullyx2's Avatar
'05 TSX CG W/NAV
Hi guys. I am having a problem with this too. Part of it is, when I clean them to aggressively or "I squeeze it like I mean it" the velcro on the back starts to seperate. I can eventually get it back on with spray adhesive after they dry. Any way around that? I was told not to put them in the washer but I may give it a shot if you say it's safe.
Old Jun 5, 2006 | 03:34 PM
dmarcus48's Avatar
I agree, I've got a pc, only thing I've used it for is taking out swirls and when I'm really lazy taking off the sealant/wax, usually just do it by hand though. TL isn't that big.
Dave
Old Jun 5, 2006 | 04:31 PM
picus's Avatar
I hear about this a lot but have never experienced it myself. I've got over 30 pads so you would think I would have, it's weird. I wash my pads in the washer quite often, just with some non fabric softener detergent like woolite.
Old Jun 5, 2006 | 10:56 PM
SweetJazz's Avatar
2016 E350 Sport
The best cleaner I have used is called "Snappy Clean". It is a citrus based powder designed to clean pads. You pour the powder packet into a 5 gallon bucket and fill about 2/3 with water. Simply massage the pad and it will come clean is seconds. You can purchase this product from a number of online detail sites. I would not recommend any harsh detergents to clean the pads and absolutely do not place them in a dryer.
Old Jun 5, 2006 | 11:22 PM
Former Sponsor
In all of the years Ive been using a PC, I have yet to deteriorate one when washing with any APC or deteriorate while using.........Just use common sense when polishing and cleaning, its quite simple folks, no rocket science.......
Old Jun 8, 2006 | 06:22 AM
bullyx2's Avatar
'05 TSX CG W/NAV
Sounds good. I have a Duet washer which is fairly gentle on things to begin with (God, I can literally hear the testosterone rush from my body as I start bragging about my washing machine). I'll pick up some Woolite while out this morning and run them through on the gentle mode later today. Thanks!
Old Jun 8, 2006 | 01:32 PM
Jesstzn's Avatar
I just use Dawn in a small pail and let the pads soak in hot water for a bit then I squirt a little Dawn directly on the pad and aggitate with my fingers then run cold water to rinse them as I kneed the pad . Once no more soap comes out I roll the pad up to wring it out .. I don't twist the pad .. then I lay them on a wire drying rack velcro side up to dry.
hashbrown
Feb 18, 2022 11:20 AM
08KBP_VA
Oct 22, 2019 01:55 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
