Cleaning the cleaning supplies
I was wondering how often, and how you all clean your cleaning supplies?
The things I have are --
Sheepskin mitts
Microfiber towels (for polishing and waffle-weave for drying)
Chennile sponge
Wheel brush
Also I'll throw a second offtopic question too -
I found this bottle of Eagle-One "wax as you go" in my garage (no idea how it got there). Anyways, is this any good? If not, is there any harm as using it as kind of a 'quick detailer" after washing -- ie would putting this on mess up my meg's nxt wax coating?
Sheepskin mitts
Chennile sponge
Wheel brush
I miss my 03 CL-S :(
I machine-wash the microfiber towels (both polish/detailing + drying) after every use with very little regular washing detergent. I machine dry without fabric softener.
I'm not sure the sheepskin mitt is safe to machine wash so I hand-wash after every use.
I don't have a wheel brush I just spray a wheel cleaner and scrub with a small sponge. Of course I've got the OEM wheels, if they were chrome or fancy aftermarket I may be using something else.
I rinse the bucket I use to wash the car very well after each use as well.
Team Anthracite Member
I wash my every week before I use them again on the car. I think it is a good idea to start with clean towels and mitt. Just follow the cleaning directions: no bleaches or fabric softeners.
Team Nighthawk MechE
I'm Baaack!
Sheepskin mitts - Wash by hand after each wash. (You don't want to rub that stuff into your paint on the next wash)
Microfiber towels (for polishing and waffle-weave for drying) - Machine wash cold after every wash .. air dry or machine dry on air setting.
Chennile sponge - Same as sheepskin mit
Wheel brush - I just wash mine in the car wash soap after I'm done with the car and rinse wel with the hose
I found this bottle of Eagle-One "wax as you go" in my garage (no idea how it got there). Anyways, is this any good? If not, is there any harm as using it as kind of a 'quick detailer" after washing -- ie would putting this on mess up my meg's nxt wax coating? - I would avoid this and get Meg's QD. I just used mine during a detail to get the dust off between rounds of polishing and was really impressed
FWIW, I emailed the people I bought my sheepskin mitt from (which has a detachable rubber inner glove so your hand stays warm and dry)... here's their response:
Total sales pitch But at least it answered my question...
Thank you for taking the time to send us your email message and your interest and Griot's Garage. I understand that you are inquiring about how to wash you Rubber Glove Lined Wash Mitt. The mitt should not be machine washed. Hand washing will prevent the deterioration and prolong the life of the mitt. What I would suggest for the dirty side is to clean it with Interior Cleaner. What I always recommend is to have two wash mitts. One mitt for the majority of the car and one specifically for the lower panels, which are generally dirtier.
I'm Baaack!
Actually the two wash mits idea is a good one ... use the second (i.e. cheaper) one for the lower panels, that way if you've picked up any road tar you won't ruin your expensive wash mit. (Trust me on this one, I'm speaking from experience)
-Sheepskin mitts
I wash mine by hand after each wash.
-Microfiber towels (for polishing and waffle-weave for drying)
Machine wash them with liquid detergnt after each use. Dry them on low heat until damp dry and the let them air dry.
- Chennile sponge
Wash by hand
-Wheel brush
Just hose it out with a stiff stream of water.
....I got the same Griot's glove in glove and got a similar response to the email inquiry. Was also told to hose it from the inside to push any dirt outward. I've tried that with Griots glove, but it just fills up.
- Chennile sponge
Wash by hand
-Wheel brush
Keep Right Except to Pass
I have the Griot's sheepskin glove without the rubber liner and have put it in the laundry machine and then hung it in the shower in the downstairs bathroom to dry. I have had no problems with it wearing prematurely, although in light of the posts above I may start handwashing it. My washer is a front-loader with no agitator, so maybe that might make a difference. The front-loader is a lot gentler on stuff than the old-fashioned top-loaders.
Guys with the Griot's glove with rubber glove inside, make sure you seperate the two when hanging them to dry. I left the rubber glove inside a few times and is now covered in black mold
When I bought a new one, I noticed the inside of the glove is now lined with cloth, which I'm sure helps a bit. Also the glove is held into the inside with velcro around the wrist area.
That happened with my last one
