Ceiling Please
Old Apr 22, 2007 | 08:40 PM
danish's Avatar
Ceiling Please
Alright i just asked on how to remove a water stain from the ceiling. Now, does anyone know how to remove smudges from a parchment ceiling? I searched and read a small thread on carpet cleaners being used and would like to know more details and probably a product that is made to do this job, not used to clean carpets. thanks.
Old Apr 22, 2007 | 08:59 PM
Anthony Orosco's Avatar
Look for some Folex cleaner, spray the cleaner ON THE towel, a cotton terry towel (white) or a microfiber towel and then apply it to the stained area. Rub and blot gently until the stain is gone.
Also, a dry cleaning fluid which can be bought at many janitorial supply houses can be used with great results.
Anthony
Old Apr 22, 2007 | 09:40 PM
exceldetail's Avatar
Former Sponsor
Anthony
.......or just use a all purpose cleaner, diluted about 10:1. Never spray the ceiling, always moisten the towel and blot/wipe stain off.
Old Apr 23, 2007 | 05:11 AM
stic2it's Avatar
My ceiling is awful, had a 9 yr old put her hands up after coming from school...
Old Apr 23, 2007 | 07:49 AM
TOGWT's Avatar
The Old Grey Whistle Test
Headliners:
Require special care and attention, as cloth type headliners are assembled with foam backing and usually glued to a fibre roof panel. If the headliner becomes wet, it can cause the head liner to delaminate and fall down. An interior cleaner (303 TM Fabric & Vinyl Cleaner) should be used. Spray onto a terry towel and wipe very gently
Do not spray products directly onto head lining. Wipe lightly making sure not to leave headliner wet. Inspect and re-clean as necessary. It is better to clean twice, rather than to allow the head liner to get too wet. An alcohol based aerosol glass cleaner may also work for this operation because of its quick evaporation. Vinyl headliners should be cleaned the same way.
[B] Methodology[/B]
•Lightly brush the headliner with a natural-latex sponge or a horsehair brush, they have very soft bristles that are gentle and is specially made for headliners or leather surfaces, this will loosen dust / dirt and make vacuuming easier (for very light dust or lint use a rolling lint brush)
•Do not use a stiff brush as you may snag or tear the headliner material
•Lightly vacuum the headliner to remove loose dust
•Spray 303 CM Cleaner & Spot Remover on to a 100% cotton terry towel
•Cleaning the headliner a quarter section at a time, use very light and even pressure on the towel to work the cleaner into the fabric. Do not saturate the material or use much pressure on the towel
•Use a fresh, clean damp, 100% cotton terry towel to remove the soil / dirt
•Frequently rinse the towel in clean warm water to ensure all dirt I soil is removed
•If the vehicle is fitted with a sunroof, open it a couple of inches, as dust build up at the front edge.
•Clean this area before closing the sunroof and proceeding to the rear of the sunroof.
Maintenance-use a Lint Roller to pick-up light dust and dirt
rockyboy
Aug 4, 2024 10:35 AM
wstevens
Home & Garden
28
Jul 22, 2005 08:11 AM
